2006 Dyna Primary Inner Bearing Race
Old Sep 29, 2007 | 09:05 PM
bzzrd2's Avatar
bzzrd2
Default 2006 Dyna Primary Inner Bearing Race
Has anyone ever installed an inner bearing race without any of the Harley Special Tools? Installing the bearing is a breeze but I notoced the race is gallled bad and needs replacing as well.
Getting the old one off will be easy enough, I'll just grind it off. I was thinking of heating the new race in the oven to 350 deg., cooling the shaft and tap gently into place. Thoughts? It's a good trick for most cup bearings in cases etc. It's actually how I installed the bearing itself in the inner case. Drops right in.
Old Sep 29, 2007 | 09:14 PM
bzzrd2's Avatar
bzzrd2
Default RE: 2006 Dyna Primary Inner Bearing Race
Here's a pic of the galling for those who like pictures.
[IMG]local://upfiles/32407/4A37D7BFA77B49F39B6B546FF22A864F.jpg[/IMG]
Old Sep 29, 2007 | 10:10 PM
mud's Avatar
mud
ORIGINAL: bzzrd2
Thoughts?
Drops right in.
Yeah I've done it.
Not a big deal.
Sounds like you already know what you're doing.
Even w/o heat,
you can drive it on with some love taps.
I believe the service manual will give you
the measurement for spacing.
Yeah, that old race is UGLY.
thanx for the picture.
mud
Old Sep 29, 2007 | 11:06 PM
hondo96inch's Avatar
hondo96inch
ORIGINAL: bzzrd2
Since this drive is coaxial, I wonder how many of these bearings are ruined by drive belt being too tight.
Every new belt drive harley I've bought had the belt too tight and out of line.
Old Jan 1, 2008 | 05:52 PM
Pixs's Avatar
Pixs
Hi Mudd,
Right through the clutch hub? The two I have had replaced required the deler to pull it.
Best,
Pixs
Old Jan 2, 2008 | 10:48 AM
mud's Avatar
mud
ORIGINAL: Pixs
Hi Mudd,
Best,
Pixs
Pixs, not quite sure about your query.
The clutch basket is not part of the equation
as it pertains to the issue buzz asked about.
The clutch basket is removed as an assembly and put aside.
He asked about installing theinner bearing race without any of the Harley Special Tools.
mud
jigoe007
22
Jun 12, 2019 09:12 AM
brad75raiders
EVO
Nov 10, 2018 07:22 PM
nevadarider
Jun 1, 2015 02:57 PM
highmarket
Jan 1, 2014 05:15 PM
brianp25
Mar 20, 2009 03:11 AM
