If you look closely these set ups are used for high tq. And you loose the collar that usually rides in the bearing But it also says it's for belt drive. Anyone run the all ***** or Baker bearing in the ipb
the bearing is sealed But it gets oil inside of it with a stock primary and that is not a bad thing reason it runs as long as the guys talked about
in a belt drive we remove the rubber shields and re pack it with a hi end synthetic grease every 5 thousand miles just to be sure some guys that's 3 - 4 years for some and some its one season - your maintenance program may need to be stepped up
