Latest Shoptroll Project
Old Oct 4, 2007 | 08:00 PM
shoptroll's Avatar
shoptroll
Default Latest Shoptroll Project
Ok, so when I put the fork bag on my Streetbob I realized that it blocks some of the headlight. So in the first pic you can see the 1/2" spacer block that I added to the stockmounting block. That still wasn't good enough to properly aim the headlight so I made a new mounting block that moves the headlight up 1 1/2" and out 3/4" from the stock position. I used 1" aluminum round stock with a 15 degree mitre on the base. The top is milled down to 3/4" flats to fit between the light brackets. The second pic is the finished product.
[IMG]local://upfiles/35650/86D48C65F2714F2B9232ECF21861640C.jpg[/IMG]
[IMG]local://upfiles/35650/7527A3533DED47B5A7EDA99548477BCA.jpg[/IMG]
Old Oct 4, 2007 | 08:21 PM
voyager1's Avatar
voyager1
Default RE: Latest Shoptroll Project
Nice job. and that is the reason i took my fork bag off. I am not that good at building stuff . I wish i was .
Old Oct 4, 2007 | 08:50 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Looks good
Dyna is the best Harley
Old Oct 4, 2007 | 08:51 PM
KeithB's Avatar
KeithB
Does that effect the headlight aim?
Old Oct 4, 2007 | 08:59 PM
cpa55's Avatar
cpa55
I mounted my soft fork bag above the light on the handle bar.
Old Oct 4, 2007 | 09:03 PM
shoptroll's Avatar
shoptroll
ORIGINAL: cpa55
I had the bag above but I didn't like how the air flowed over it & up under my glasses.
KeithB
Date 10/4/2007 9:51:30 PM
Does that effect the headlight aim? I just re-aimed the headlight to where I wanted it.
Old Oct 4, 2007 | 09:09 PM
KeithB's Avatar
KeithB
ORIGINAL: shoptroll
Does that effect the headlight aim? I just re-aimed the headlight to wherer I wanted it.
That works
Joshus41
Aug 8, 2016 03:03 PM
bbqbrisket
Aug 8, 2016 01:07 PM
Johnnyh14
Oct 9, 2014 12:53 PM
BMyers
Sep 15, 2012 08:15 AM
Pipedream
Apr 10, 2008 04:30 PM
