Rocks in my engine????
In the good old days (pre CDI/EFI) you had to set your ignition timing to the correct crankshaft angle before the piston reached top dead centre on the firing stroke. Once you got this base setting correct the advance/retard mechanism in the ignition changed the setting continually depending on the accelerationyou asked of the engine. You may remember the little weights and springs that use to tear round underneath the points/condenser that allowed the cam to turn slightly independently of the engine drive shaft. This is what allowed the timing to adjust automatically dependent on acceleration.
Even so, setting the timing was always a fine balance between getting an engine to run and getting it to start (and sometimes neither!!).
Nowadays the control over the fuelling and the spark timing with CDI and EFI is much much better but even so you should not give it the berries in too low a gear. If you make a habit of doing this - you will, as sure as eggs is eggs, damage your engine.
The Octane rating of the fuel (RON) has a heavy bearing on this. The lower the value the more the possibility of pinking. In jolly old England our 2 star fuel is around 92 Octane and is not too much of a problem. I understand in the colonies it can be as low as 87 Octane which certainly doesn't help.
So the upshot is - lugging an engine is bad for the bearings etc. but lugging it and trying to compensate with the gas is much worse.
This is a test, I'll be asking questions later on
All the best
Walt
