Black sparkplugs
Old Oct 7, 2007 | 08:13 AM
stbobber's Avatar
stbobber
Default Black sparkplugs
Took her out last nite had to turn around, running real rough, Dropped the plugs and they werecoated black. I washed it but have not started it in 3 weeks (bad weather).
06 bob V&h S/E ac & powercommander.
I'll change the plugs today, whats it mean when your plugs are black?
Old Oct 7, 2007 | 08:33 AM
boogiewithtuck's Avatar
boogiewithtuck
Default RE: Black sparkplugs
ORIGINAL: stbobber
Black would typically indicate its running rich. Can you post a close up pic of the plugs? Were they dry of oil fouled?
Old Oct 7, 2007 | 08:36 AM
boogiewithtuck
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
This link might help you with your diagnosis...
Old Oct 7, 2007 | 09:53 AM
stbobber's Avatar
stbobber
thet were dry, almost like a powder coating.
Old Oct 7, 2007 | 07:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
i realize it's been a while since it was washed but check your connections to your power comm. for water intrusion and corrosion on the pins, seen this a few times on this board. may also want to check your sparkplug connections and coil connections, may want to apply some dielectric grease on your coil and plug connecters, just a thought. good luck and ride safe.
Old Oct 7, 2007 | 08:56 PM
DougsDyna's Avatar
DougsDyna
Yep, running too rich................. Better than running too lean.
Do what SSE8 said, and maybe consider a leaner map setup.
Good luck and keep us posted.
DougJ
Old Oct 8, 2007 | 07:36 PM
WildBill76's Avatar
WildBill76
Make sure to change you oil if it turns out they were fouled by too much gas. Otherwise you will end up with oil fouled plugs and worn bearings.
reedrdglide
Mar 3, 2014 11:37 PM
DrRude
Exhaust System Topics
Aug 26, 2009 08:23 AM
bL33d
Feb 2, 2009 08:43 AM
