I seem to have developed a rattle at my pipes from the back chamber,also i can loosen it up but cannot remove the slip on is there a hidden connection?does anyone have problem with internal welds breaking loose from baffle.Seems to rattle more when engine up to temperature.Thanks for input.
I have SEII's and I'm not sure what you meanby "back chamber". I would remove the baffles by removing the two bolts holding them and using a hanger to hook the baffle and give it a yank. I've used a wooden punch on the baffle inside the pipe to free the crust so the baffle comes out. Check your baffles out for cracks. Also check the torque on your pipe clamps and the bolts and nuts on the connector from pipe to pipe. Let us know what happens.
