Trimming Windshield
Old Oct 21, 2007 | 05:30 PM
shawn e.'s Avatar
shawn e.
Default Trimming Windshield
I want to trim my super sport windshield so it doesnt hang over my headlight. I am guessing I should tape where I cut and tape the foot of the jig saw as well? Any suggestions or warnings. I have faith in my ability to cut it just not sure if there is anything I should know about plexiglass.
Thanks Shawn
Old Oct 22, 2007 | 01:36 AM
JRK5892's Avatar
JRK5892
Default RE: Trimming Windshield
do a search on google i do not remember where but there is a step by step how to out there, i did it a few years ago making a fairing for my cafe... i will look to see if i saved it... i know i found it just googling it
Old Oct 22, 2007 | 01:59 AM
20LowRider02's Avatar
20LowRider02
I've been looking into this. I guess you just mask it off...the good area so it doesn't scratch it, then cut with the jig saw. I was going to use a coping saw because I want to have more control. Then sand to match the rounded edge. Then use Methyl Ethyl Ketone (spelling) to "melt" the edge to make it clear. Only get the MEK where you need it...it will mark the windshield if you use too much. They say to practice on the scrap edge to get the technique down.
Google it and you'll find articles
Old Oct 22, 2007 | 06:34 AM
recross's Avatar
recross
mast the area you're cutting...fine jig saw blade....we use velcro on the jig saw base....edges can be finished off with a dremel tool with drum sander and a fine metal file....takes some time to do but will look as good as store bought..........BC
Old Oct 22, 2007 | 07:20 AM
Travlinman314's Avatar
Travlinman314
I traced the curve of the headlight onto a piece of cardboard, cut the cardboard to make the template.
Placed the template onto the windshield, marked it with a black marker.
Used a Dremel with the #561 Multipurpose cutting bit, no tape, but did protect the shieldwith blanket underneath to prevent scratching.
When finished with cut, changed Dremel bit to drum sander, finished off any rough cuts and edges, then hand sanded to a smooth rounded finish.
It took me about an hour tops, and I did practice a little on part I knew was going to be cut off. I had never done this before, and saw this link below. They also say to use a jig saw, but in my opinion, if you have a Dremel type tool, the bit was about $5, well worth it, and easy to do.
http://www.motorcyclecruiser.com/tec...ve_windshield/
Old Oct 22, 2007 | 09:15 AM
shawn e.'s Avatar
shawn e.
Great, thanks for the tips and advice.
Shawn
Old Oct 22, 2007 | 09:24 AM
Travlinman314
Almost forgot, the website I posted above, tells you to do it on the bike. I didn't do this, and glad I didn't.
I did it on a workbench, on top of a blanket, and it made a fair sized mess, shavings and dust. Just thought I'd mention that.
Old Oct 22, 2007 | 09:57 AM
matkiwi's Avatar
matkiwi
What he says ... ie use a dremel rather than a jig saw (where you run the risk of it catching = crack or jumping) ... a dremel carefully handled will do it, any wobbles can be sorted with sanding.
Mat
wombat457
EVO
69
Jun 5, 2015 08:29 PM
betho61
Dec 22, 2014 08:56 PM
ginboy64
Jul 10, 2010 09:00 AM
jetmech
Dec 6, 2006 04:04 PM
chunks
Jul 11, 2005 10:27 AM
