another springer dyna
Old Oct 29, 2007 | 04:20 PM
  #31
Mike07FLHTC's Avatar
Mike07FLHTC
Default RE: another springer dyna
bolverk,
My springer feels better then stock.Not as mushy no nose dive.The springers with out the shock will bounce more but I think they look better.I got the one with the shock cause I really like to ride my bike and didnt want to give up to much of the ride.Now mine is a 6' over stock length so I do feel some flex in the front end if I hit a bump in the corners.Not scary or anything but I can feel it.Also keep in mind as you read this I added rake to my neck 10 deg to give me 38degs.That will smooth out the ride when you make the wheel base longer. Hope this helps. Mike
Super01,
You can get covered shocks from Jirehs Cycles for about $70 bucks now you get what you pay for so If you want good ones Progressive makes the covered 412's also for about $300.
Mike
Old Oct 29, 2007 | 08:15 PM
  #32
WarriorHD's Avatar
WarriorHD
Whoa! That is one SWEET custom you built there. AWESOME!
Old Oct 29, 2007 | 08:44 PM
  #33
lolife's Avatar
lolife
That ****** rocks................................. . . . . . .................
Old Oct 29, 2007 | 09:32 PM
  #34
SUPER01's Avatar
SUPER01
Thanks Mike.
Buy cheap buy twice.
I'll start saving up some $ for the Progressive.
Old Nov 4, 2007 | 02:52 AM
  #35
Shred4204's Avatar
Shred4204
Thanks for info!..
How wide is the belt?..possibly have the model/or part numbers?..on the belt drive..
Does it make that cool whine noise?..[8D]
Old Nov 4, 2007 | 08:23 AM
  #36
Mike07FLHTC
Shred,
The belt is 3' wide kit.Yes it does whine.I forget the part# you should go to http://www.beltdrives.com/then find the one you need for your year.They have with the outboard bearing support and without.Then go to http://www.jirehcycles.com/.I got mine for about $1500 saved like $500 at Jirehs.If I can help just drop me a line.
Mike
Old Nov 4, 2007 | 11:29 AM
  #37
traveler's Avatar
traveler
This FXD should be put in for bike of the month, IMHO.
~Joe
Old Nov 4, 2007 | 02:54 PM
  #38
Shred4204's Avatar
Shred4204
Thanks Mike!.......But..I see one for up to 05' FX...same?..
Old Nov 4, 2007 | 06:01 PM
  #39
Mike07FLHTC
I looked up the part # in the Jirehs book #58-543 for 1990 to 2001 Dyna part# 58-544, 2000 and later.Both kits are $1599 from Jirehs. BDL list them for around $2500.
Mike
Both kits are with the outer bearing support like mine.
Old Nov 4, 2007 | 06:06 PM
  #40
Ultra_Bob's Avatar
Ultra_Bob
Nice looking bike.
Iron lHorse
Jun 12, 2014 02:56 PM
MadScientist323
Dec 7, 2012 10:14 PM
mont
Nov 5, 2008 08:12 AM
Abdon
Apr 8, 2007 02:58 AM
topchop
Mar 3, 2006 09:56 PM
