Dyna Alternator Output
Old Oct 25, 2007 | 09:47 PM
rewog's Avatar
rewog
Default Dyna Alternator Output
I'm interested in adding some extra lighting to my LR. Can anyone tell me what the actual output of the alternator is?
Old Oct 25, 2007 | 09:49 PM
JRK5892's Avatar
JRK5892
Default RE: Dyna Alternator Output
you will be fine... i do not know what it is but i run, fog lights, over 100 leds, fork bag stereo and the bike off mine and it runs like a top!
Old Oct 25, 2007 | 10:20 PM
DougsDyna's Avatar
DougsDyna
I've got heated grips, heated goves, heated liner, and a lighter that pushed in every 20 minutes or so. No problem!!
Amperage is regulated @34-38 amps, though @ 3600 RPM.
DougJ
Old Oct 27, 2007 | 04:42 PM
Twinrider's Avatar
Twinrider
Here's info for a 2003 FXD.
ELECTRIC Battery Sealed 12-volt, 19 amp-hour, 270 cca (per Battery Council International rating) Charging 28-amp permanent magnet alternator w/ solid-state regulator (364 watts @ 3,000 rpm, 416 watts peak
Here's the draw:
Starting 1.2 kw electric w/ Bendix-type engagement Lights: (As per country regulation) Headlamp Quartz halogen 55-watt low beam, 60-watt high beam Tail/stop lights 8w/28w (int’l: 5w/21w) Turn signal lights (self-canceling) 28w (int’l: 21w) Indicator lamps High beam, neutral, oil pressure, engine diagnostic light, turn signals and security system (optional)
Source:
http://www.skatelink.com/haphfxddysug.html
Old Oct 27, 2007 | 04:51 PM
matkiwi's Avatar
matkiwi
I'd use a relay for the extra lights though if they are Halogen so you don't overload the circuit ... the battery and Alternator should be fine.
Old Oct 27, 2007 | 05:28 PM
[Rowdy]'s Avatar
[Rowdy]
Should be in the high 30's, close to 45 on start-up.
-Ryan "Rowdy."
apetterez
Jan 6, 2015 08:25 PM
jakeda
May 2, 2014 10:02 PM
ironman2011
Dec 6, 2010 08:19 AM
grgerman
Oct 20, 2010 09:28 PM
waterman7474
Aug 7, 2006 12:52 AM
