Fork Oil
Old Oct 29, 2007 | 02:55 PM
HDUK's Avatar
HDUK
Default Fork Oil
Anybody know the correctqty of fork oil that goes in to each fork on a 2005 Dyna Custom
Old Oct 29, 2007 | 05:37 PM
Patch's Avatar
Patch
Default RE: Fork Oil
I too have a 2005 FXDCI.I am at work now ,If nobody gets you the number by tomorrow I will look it up when I get home, I have the 2005 Dyna shop manual.
Old Oct 30, 2007 | 12:51 PM
HDUK's Avatar
HDUK
Thanks Patch that would be a great help, as I need to change the fork oil in my wifes bike
Old Oct 30, 2007 | 07:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
for what it's worth my 02 takes 10.6 ozs. I put 11 in it and called it good. the 02 has the 39mm forks.
Old Oct 31, 2007 | 06:40 PM
Patch's Avatar
Patch
According to my 2005 HD Dyna shop manuel.....2005 FXDC is 10.6 ounces as stated above. good luck
Old Nov 4, 2007 | 01:15 PM
HDUK's Avatar
HDUK
Thanks patch when I lowered my wifes Dyna my local HD dealer recormended Screamin Eagle fork oil, put that turned out to be to heavy for road use and has made the ride to harsh, should have gone with with normal fork oil, but I thought the dealer new best
Old Nov 4, 2007 | 01:25 PM
Patch's Avatar
Patch
I too tried the SE fork oil but found it too heavy...an extra 1/2 ounce worked out well for me and did not cause the fork seals to leak.
Old Nov 4, 2007 | 01:45 PM
HDUK's Avatar
HDUK
I was abit niffed with the dealer again giving duff advice, as the dyna has been lowered they said the SE oil would give a better ride, you can feel every bump in the road with it
Old Nov 4, 2007 | 06:11 PM
seniorsuperglideE8
for what it's worth when i changed mine i used BEL-RAY 10w, i've read that Type E oil is 5w oil. i wanted something heavier to work with more two up riding. hd has packaged their oil where it requires two bottles. Bel Ray is in a 1 liter bottle. i think the 10w would be good with forks that may have less compression travel. good luck and ride safe
Old Nov 8, 2007 | 10:22 AM
04fxdwgi's Avatar
04fxdwgi
Just rebuilt forks on my 04 Wide Glide. Mixed 5w and 10w ( to get around 7.5 ) stiffened up enough to prevent nose dive, but not enough to make rough.
Steel Steed
Jul 9, 2012 06:59 AM
Desertdog7
Apr 1, 2010 11:04 PM
Headwolf
Jul 22, 2009 01:09 PM
PDDGM
Apr 5, 2009 09:49 AM
bbissell
Aug 13, 2008 09:27 PM
