Anyone else got a problem with a wobble?
Old Oct 29, 2007 | 10:02 PM
tree88's Avatar
tree88
Default Anyone else got a problem with a wobble?
I'm pretty sure the bars and solid riser bushings are making the problem worse, but the wobble was there with the old bars too. Was in the process of passing a semi this weekend, doing about 85 when she decided to do her best impression of a saddle-bronc. I pulled over, removed the seat cover from my a** and let about 15lbs out of the front tire- seemed to help some. I ordered the drag specialties steering stabilizer kit for her, and when it gets here I'll let yall know if it fixes the issue. I was just curious if i was the only one experiencing this issue.
Old Oct 29, 2007 | 10:53 PM
WildBill76's Avatar
WildBill76
Default RE: Anyone else got a problem with a wobble?
Nope ! Bike is very steady. Maybe you hit a Ford Trail ( Oil That Leaks from Fords Crank seals ) ( They lose about a quart every 250 to 500 miles.) ( At least, that is what my Ford dealer said is normal for a new Ford Product.He has sold Ford products for over 40 years. It use to be 50 to 100 miles. ) My Lincoln Product no longer leaks oil. It burst into flames, while parked. Something about a Cruise Control Brake Switch.
Old Oct 30, 2007 | 09:01 AM
ride99fxd's Avatar
ride99fxd
Check the tightness of the hardware on the top motor mount (the one that attaches to the heads).
Old Oct 30, 2007 | 09:03 AM
lolife's Avatar
lolife
has it been lowered in the rear............... . . . .
Old Oct 30, 2007 | 09:05 AM
sleepneagle's Avatar
sleepneagle
lube the neck bearings and adjust the pre-load on the neck bearings.
Old Oct 30, 2007 | 09:06 AM
grizzly's Avatar
grizzly
Only wobble I get is on decel, at slow speeds. Kind of strange....anyone have that problem or know the cause?
Old Oct 30, 2007 | 09:47 AM
arkieollie's Avatar
arkieollie
I really think it's the road. Sometimes when I get up to around 85-90 mph there is no wobble at all.....other times it wobbles so much it scares me. But I will say that I have never gotton any wobble while on the interstate that I can remember....only on state highways. This is what leads me to believe it is the road and not the bike. I remember coming home from Denver and I stayed at a 80 mph clip and never a wobble once (even in Kansas where the wind was horrific). Maybe its the "lean" in the road or the uneveness of state highways...I don't know. I may invest in a stabilizer...until then, when I wobble I'll just slow down!
Old Oct 30, 2007 | 10:09 AM
bdn56's Avatar
bdn56
I was lucky with wobble. When I changed out my front tire, the wobble stopped. Changed from a Dunlap to a Metzler.
[IMG]local://upfiles/28484/1461879700664101B83A2B1ACC13E7C8.jpg[/IMG]
Old Oct 30, 2007 | 11:45 AM
99_percenter's Avatar
99_percenter
ORIGINAL: tree88
Check out this article in Planet Biker's online magazine..
pretty interesting read...
http://planetbiker.net/october2007.pdf
MOTORCYCLING 101 Page 4
The Harley Wobble. Does it really exist?
by Mike Luikey
99%r
Old Oct 30, 2007 | 05:12 PM
tree88's Avatar
tree88
ORIGINAL: lolife
Yes it has approx 2 inches.
