Oil Light Flicker???????
Old Oct 31, 2007 | 11:11 AM
chadmiller62102's Avatar
chadmiller62102
Default Oil Light Flicker???????
I have an 07 Street Bob that has just hit 5700 miles. Occassionaly, usually while just cruising, the oil light will flicker quickly. Short, quick oil light, then off. I plan on taking it to the dealer, but anyone have any idea what would cause this? Also any possiblilty the dealer would pull some bs to say it's not covered under the warranty or say it's fine. Thanks
Old Oct 31, 2007 | 12:06 PM
bikerdog134's Avatar
bikerdog134
Default RE: Oil Light Flicker???????
know this is obvious but have you checked your oil with the bike level. and yes, the stealer could ba an a--
Old Oct 31, 2007 | 12:19 PM
dyna07custom's Avatar
dyna07custom
what oil are you running? is it full? check connection of sending unit r/front of motor
Old Oct 31, 2007 | 12:23 PM
chadmiller62102
Checked oil on kickstand both hot and cold, no issues there. I'm running HD 20w50.
Old Oct 31, 2007 | 02:24 PM
darkdyna06's Avatar
darkdyna06
Mine did that too the first week I had it, and I think once since then. Ive had the bike over a year now and it hasnt seized yet "knock on wood".
Old Oct 31, 2007 | 07:12 PM
DougsDyna's Avatar
DougsDyna
Maybe just nothing, but follow through on your plan to go to the dealership. Get the problem documented.
It doesn't matter if they say it is nothing or they say they found a problem and fixed it. Get it in the shop immediately and have them look at it.
Once they open a service order on it, you concern is in the system.
Hope its nothing, Good luck
DougJ
SkidMarks
Oil Archive (no new posts)
Jun 1, 2018 07:57 PM
Scot7449
Mar 19, 2015 10:49 AM
RobertV
Jan 12, 2013 10:53 AM
Robert Strohl
May 8, 2012 12:15 PM
RoadKing02C
Sep 20, 2006 05:31 PM
