Quick detach windshield and head light problems.
Old Nov 6, 2007 | 06:48 AM
Ybnormal67's Avatar
Ybnormal67
Default Quick detach windshield and head light problems.
Hey all,
I was wondering if anyone else has had or still has this problem and if so you did you fix it???
I have an 07 Street Bob with the Harley Quick Detach Windshield installed with stock head light. I rode last night at night for the first time ( Not by choice ). The stock light ( bulb ) is less than desirable for light out put and I have found suggestions to fix that. Any way I rode with my hi beam when I could and the windshield sticks out just far enough to capture some light and reflect it back making it almost impossible to see with the hi beam on. Can this be fixed with a trim ring or visor ??? I like the look of the smaller stock light and do not want to install a bullet style light. Any suggestions for making the stock light work??
Thanks
Joe
[IMG]local://upfiles/43328/E475B6C448B7443298539E85830C8990.jpg[/IMG]
Old Nov 6, 2007 | 07:06 AM
ss377's Avatar
ss377
Default RE: Quick detach windshield and head light problems.
Same problem on my 06 St Bob. I just raised the height of the windshield.Theclamps are about 1/2 inch from the top tree clamps, big difference, no reflecting. I am still running the stock head light.
Old Nov 6, 2007 | 07:14 AM
jmpancoast's Avatar
jmpancoast
I installed a HD trim ring on my Dyna headlight before I put a different headlight on it. This was also before I purchase a windshield. It extended the front edge of the headlight out about an inch which should be enough to help with your issue.
Old Nov 6, 2007 | 07:19 AM
dyna07custom's Avatar
dyna07custom
Raise windshield 1/2 inch
Old Nov 6, 2007 | 07:20 AM
Sammi's Avatar
Sammi
Had the same problem with glare on high beams and didn't want to raise the windshield.
I insalled a visor ring - the "Frenched" version.
Did the trick.
Sammi
Old Nov 6, 2007 | 08:15 AM
Dynamite17's Avatar
Dynamite17
ORIGINAL: Ybnormal67
Hey all,
Thanks
Joe
I had the same problem, solved the issue with the headlight trim ring HD p/n 69735-05
Order here
Looks like this on my setup:
Added the US flag sticker later, not related to the problem!
B
Old Nov 6, 2007 | 11:11 AM
DougsDyna's Avatar
DougsDyna
I had the visor ring installed already, before the windsheild.
Don't have any "glare" issues.
DougJ
Old Nov 6, 2007 | 11:32 AM
tideglide's Avatar
tideglide
Yep, the viser I installed sticks 2" past my windshield. Fixed the problem.
Old Nov 6, 2007 | 12:25 PM
rob_will's Avatar
rob_will
I did the same thing..I installed the skull visor....problem solved
sledgeb1
Jul 27, 2016 10:19 AM
1st 96 ultra
2014-2024 Touring Models
Feb 10, 2015 06:49 PM
Foodog2
Feb 23, 2014 04:53 PM
easy4me
Nov 7, 2007 12:41 AM
bobg1253
Jul 28, 2005 02:10 PM
