and triple check your wiring is correct before buttoning everything up.
Not sure why you need an extention - the headlight cable is one of the bundles that has the most slack. If you tug gently on itcoming out of the neck, it will give you as much as another 8 inches if you need it.
Anyone have a headlight extension on the FXDB? Where you found one and a part number would be nice. Any wire issues? Thanks
Not sure if this is what you're looking for twofish, but this is the Headwinds headlight mount I installed with my new powder coated 5-3/4 headlight - no issues on install as long as your headlight has a bottom mount two prongy thingy. Moves headlight up and out as per specs in link:
