Deuce yes - I will be putting one on my FXDBI when the bearings and sleeve arrive. Because my wheel is for a 3/4" axle, I have to bore it for the sleeve. You should be OK.
The sportster wheel is 16" with a 150mm tyre I think whereas the deuce will take the SE 180 tyre.
if you buy the wheel new you will need to buy 1" bearings and sleeve. If it is off of soft tail you will need to remove 3/4" bearing and sleeve. then replace with 1". Dyna has 1" axle
Topspin -- just an FYI to let you know you do not need a new wheel to utilize a 180 tire. You can throw one on your existing wheel.
If you want a solid wheel for looks.... well then by all means post some pics when you're finished because I'll most likely be doing something similar by spring.
you can use a deuce wheel you just have to switch the wheel bearings. I have an 03 deuce wheel ready to put on a 06 streetbob took it to a local bike shop to have 3/4" bearings removed and 1" bearings installed . as long as your dyna is 06 or newer.
I've considered a Deuce wheel as I really like its look. But, the rear wheel is so covered up by the shocks, rotor, etc. that I decided to leave the spokes for now.
As Wyde Glyde Bry said above, you can install a 180 with the stock wheel. I did. I have the SE 180. It feels fantastic but it's very soft and will wear too fast for my wallet. I'll be looking for a 180 alternative soon.
