Installing Motherwell Rack
Old Nov 27, 2007 | 08:23 PM
Matrix's Avatar
Matrix
Default Installing Motherwell Rack
Is there supposed to be a nut in place under the fender to secure the back of the rack to or must I get one from the dealer or hardware store.
I expected that I would find the same type of nut that secures the rear of the seat.
Am I missing something?
Old Nov 27, 2007 | 08:26 PM
Trotter's Avatar
Trotter
Default RE: Installing Motherwell Rack
The Nut .....59768-97
Old Nov 27, 2007 | 08:53 PM
RonnR's Avatar
RonnR
ORIGINAL: Matrix
Like Trotter said...... Your right its the same as the seat device.. Just had to get one yesterday.. $3.00 at your local dealer..
Some advice,, get a couple, I'm on my 3rd one, but have a 4th in the drawer..
Old Nov 27, 2007 | 09:01 PM
PigInaBlanket's Avatar
PigInaBlanket
I got one from Motherwells whenI ordered the rack. Why are you going through so many RonnR? The one I got has a a clip holding the nut onto the fenderand I've never had any problems losing it or anything.
Old Nov 27, 2007 | 09:28 PM
RonnR's Avatar
RonnR
Needed The 1st= I have no idea, I was washig the bike noticed the seat a little loose so I backed the screw out and the fender nut fell to the floor and down a drain pipe..(The little black plastic horseshoe no where to be found)..
Needed the 2nd= when I bought the motherswell
Needed The 3rd= the bike was falling off the lift and I grabed the edge of the seat to balance, and 'pop' there went that one...
The 4th is in the garage, in a drawer, just patiently waiting for its turn..
RR
Old Nov 27, 2007 | 09:49 PM
PigInaBlanket
Damn that sounds like my ex wife, it sucks.
Old Nov 27, 2007 | 09:50 PM
cpa55's Avatar
cpa55
Maybe there is a metal horseshoe to replace the plastic one. I will remove mine when I have time and take it to Home Depot, if someone beats me to it, let us know the part #.
Old Nov 27, 2007 | 09:56 PM
Matrix's Avatar
Matrix
I don't know if I should have but I found a teflon lock nut in my shop that fit the supplied bolt that came with the Motherwell Rack.
My wife was able to get her arm between the fender and the tire. She was able to hold it in place with a wrench until I was able to tighten it. I put a stainless flat washer between the teflon lock nut and the fender.
Do you think that will work ok?????
Old Nov 27, 2007 | 10:05 PM
RonnR's Avatar
RonnR
Matrix
That should be OK as long as the washer is flush with fender,, And (this is a big and) And if your wife gets her arm out before you ride...
Old Nov 27, 2007 | 10:07 PM
PigInaBlanket
As long as the bolt when screwed into the nut isn't sticking out too far to maybe hit the tire when bottoming out on a bad bump or something then I imagine it should work fine.
You will just have to be careful if you ever unbolt it so that you don't lose the nut and washer.
