simple question please help
Old Nov 28, 2007 | 09:10 PM
street2007bob's Avatar
street2007bob
Default simple question please help
I dont know my terms but I will do my best to describe. I want to remove bolts in chrome/steel "strip"the just behind the seat and put in my own custom brackets for a sissy bar I'm building. The problem occurred when I removed the bolt and the parts behind the chrome and steel stayed there. I thought that when I removed the bolt that all would come out and I could reassemble with my bracket in there also, but I guess not. How do you remove the parts behind there? How is a sissy bar bracket bought from a retailer attached in the front hole-- not concerned about the back hole really.
Old Nov 28, 2007 | 09:17 PM
JRK5892's Avatar
JRK5892
Default RE: simple question please help
hey bud i would love to help you out but i am just not understanding what you are talking about... you are refering to the chrome rear strut cover? or the black under it... the black under it is your rear struts and that is part of the frame... i have a detachable sissy bar on mine and it was a back plate and longer bolts that bolted on it was simple... if you want to take off the covers you are going to have to remove your rear turn signals as well... i am not sure if this helps at all... some pics would help the master minds on here help ya out
Old Nov 28, 2007 | 09:31 PM
street2007bob
I want to romove this bolt and put my bracket flush to the fender(with a urathan washer between) but when I took the bolt out there is still "stuff" attaached to the fender. hope the picture is visable
Old Nov 28, 2007 | 09:33 PM
anubisss's Avatar
anubisss
He wants to remove strut bolts...
Old Nov 28, 2007 | 09:48 PM
PsTaN's Avatar
PsTaN
Street ....
There are 4 fasteners, 2 in each strut, that hold your fender in place. The rear are actually bolts that go in from the inside of the fender and threadin tothe stalksof your rear signals. The front fasteners are torx heads thatmountfrom the outside. Now, if you look closely inside your fender.... either side ....you will seea support strip that is held in place by the fasteners on that side(front and rear).I believe this strip is what you wantgone ..... and you will need to removeboth fastenerson each side to get that out. Wereit me, I'dleave that support in place if possible.
Also ..... You will probably needa lift to getthe tire clearance toremove those rear fasteners.And,work on one side at a time .... take all four of those fasteners out and you'll probably wish you had 4 hands .... 2 to hold the fender back in place while the other two try and thread bolts !!
EDIT : There are also two Spacers/Washers that are glued in place on the fender wherethose front bolts are. They are there so that your fender doesnt flare out to the struts when you torque it all down.
Hope this helps !!
PsTaN
Old Nov 28, 2007 | 09:56 PM
street2007bob
I know the strip that you are talking about and I would like to remove nothing if possible just slip in a 3/16thick piece of steel in and replace the bolt.
My plan is toattach sissy bar to metal tabs sticking up from both strut bolts and then a support bar going back to the two up seat bolt----possible?
Old Nov 28, 2007 | 09:59 PM
street2007bob
The spacer bolts are what I believe I want removed then a urathan washer and my metal tab inseted between frame and fender.
Old Nov 28, 2007 | 10:43 PM
PsTaN's Avatar
PsTaN
H-D Rigid sideplates arent flat .... they are bent at the bottom and those spacers in the frontstay in there on install. However, I do believe you should be able to use the urethane washers and some ingenuity to get what you want and not damage anything. I'm looking forward to pics of your work when you complete it!!
PsTaN
Scorpio49
Sep 12, 2020 09:15 AM
kwrdkc
Mar 14, 2017 10:13 PM
ToddB3204
EVO
May 24, 2015 12:59 AM
WhiskeyHarley
Mar 4, 2013 01:55 PM
joetst2
May 28, 2006 09:32 PM
