Hole
Old Dec 15, 2007 | 05:49 PM
YellowHawk's Avatar
YellowHawk
Default Hole
I got a 2006 Super Glide a few months ago. Just today I noticed today that there is a hole through the (I guess the axle) and seems like a bolt or something should be there but I'm not sure. Does anyone know what goes there if anything? If not, what's the hole through it for?
[IMG]local://upfiles/47705/0C4D0EEE92BA4E2AABE84BD809724CA4.jpg[/IMG]
Old Dec 15, 2007 | 06:05 PM
moosh's Avatar
moosh
Default RE: Hole
if it's what I am visualizing, it's supposed to be there...used to hold the axle from turning while you remove the nut on opposite end
Old Dec 15, 2007 | 06:12 PM
YellowHawk's Avatar
YellowHawk
Default RE: Hole
That makes sense....just didn't want my wheel to come off going down the road. Nothing seemed loose and it rides fine. I just wanted to make sure.
Old Dec 15, 2007 | 06:18 PM
mud's Avatar
mud
Default RE: Hole
ORIGINAL: YellowHawk
Hawk, the hole is for the insertion of a piece of7/16" round stock.
or a 7/16" drill bit.
To keep from pulling the axle out of position
when tightening the axle nut.
Good to look critically at your machine.
Keep it up.
Good practice.
mud
Old Dec 15, 2007 | 06:35 PM
Lone Watie's Avatar
Lone Watie
Default RE: Hole
I saw the same thing on my Fat Bob, and worried they forgot a bolt, so I went to the dealer and chinese engineered it, you know, looked at the other Bob they had, was the same, and figured they couldn't be that retarded twice and felt better. Then I looked in my service manual and saw that all was okay.
Old Dec 15, 2007 | 08:02 PM
DougsDyna's Avatar
DougsDyna
Default RE: Hole
Yellowhawk, You got good answers to that particular question................ In that same general area, be conscieous of the axle cap.
The 2 screws/bolts that hold that on tend to loosen every once in awhile, as several on the forum have learned. Check em every several thousand miles or so. Da utter hole won't do ya much good ifin ya loose dat axle capinscrews.
DougJ
Old Dec 15, 2007 | 10:37 PM
YellowHawk's Avatar
YellowHawk
Default RE: Hole
Thanks for the help. Now I can rest a little easier.
Dynamite17
2014-2024 Touring Models
Aug 13, 2014 10:09 PM
Hinson
May 26, 2012 08:11 PM
RazorFXDB
Apr 16, 2008 06:10 PM
Bushy
Oct 31, 2007 11:01 PM
eventiller
Oct 20, 2005 03:58 PM
