Air filter question
Old Dec 24, 2007 | 12:22 PM
YellowHawk's Avatar
YellowHawk
Default Air filter question
This is likely a dumb question and I'm pretty sure the answer is no but....the stock air cleaner on an 06 Super Glide....is it washable or just a throw away and replace? Also, if I went with a K&N, would I need to have the fuel injection remapped? It still has the factory exhaust and factory air intake. Thanks!
Old Dec 24, 2007 | 12:31 PM
JayFromPa's Avatar
JayFromPa
Default RE: Air filter question
See Dougs response. Apparently I am incorrect about the stock filter. [sm=bustedsign.gif]
Aftermarket ones like the K/N or Big Sucker are washable.
If you go with a high fllow a/c your going to need to remap. HD's run to lean as it is.
Old Dec 24, 2007 | 12:37 PM
YellowHawk's Avatar
YellowHawk
Okay, so I would be better off just waiting and changing the exhaust and throw on the SE stage 1 intake and then go have it remapped hugh?
Old Dec 24, 2007 | 01:08 PM
DougsDyna's Avatar
DougsDyna
Wow Jayhold there!!.
The stock air filter on an 06 FXD is washable. Page 121 in the Dyna owners manual explains:
"The paper/wire mesh air filter element should be washed in luke warm water with a mild detergent."
Blow dry it with low pressure air, from the inside of the filter,or let it air dry.
DO NOT use air cleaner oil on the Harley-Davidson paper/wire mesh air filter element.
Hope that answers your question.
DougJ
Old Dec 24, 2007 | 04:35 PM
YellowHawk's Avatar
YellowHawk
Hmmm...that's good news. Thanks Doug. Thank you too Jay.
Old Dec 24, 2007 | 10:05 PM
DougsDyna's Avatar
DougsDyna
I agree with Jay on the need to either remap or put some sort of enrichener on your bike. Hope others will chime in.
Last thing your want to do is burn a hole in a piston.
DougJ
Old Dec 24, 2007 | 10:30 PM
mud's Avatar
mud
ORIGINAL: DougsDyna
DougJ
More than a few folks have posted in here that their
stock air filter melted when they washed it.
mud
Old Dec 25, 2007 | 08:27 AM
DougsDyna's Avatar
DougsDyna
ORIGINAL: mudpuddle
ORIGINAL: DougsDyna
DougJ
mud
Sounds like it is time for a filter poll............... I believe everything I readin the owners manual.
I just put my stock filter back on, after running the K&N full flow kit for 2 years. The stock filter only had about 1500 miles on it, so wasn't in need of washing. Guess I better have a spare ready, before I give mine a bath.
Jay, looks like you may be right about tossing the OEM filter................ anyone else know????
DougJ
skov
Exhaust System Topics
Jan 21, 2013 12:21 PM
cpotts454
Jul 16, 2010 11:40 PM
BadNight09
Mar 21, 2009 11:49 AM
Pythagrean
Jul 11, 2008 10:45 AM
rocamotacoca
Jan 7, 2006 01:33 AM
