Primary case drain plug
Old Dec 26, 2007 | 01:35 PM
BONES206's Avatar
BONES206
Default Primary case drain plug
I installed my new Derby cover today (Christmas gift), and changed the primary oilwhile I was at it (Amsoil 20-50).
The manual instructs to leave the drain plug .16 -.18" below the case. I'm certain when I removed the oldplug it was flush
with the case. How far do youtighten your plug?
Old Dec 26, 2007 | 02:40 PM
96 Wide Glide's Avatar
96 Wide Glide
Default RE: Primary case drain plug
I just tighten mine till it's snug, with a 1/4" ratchet. Dont tighten the crap out of it, or you could crack your case!
Old Dec 26, 2007 | 04:43 PM
peppi's Avatar
peppi
It shouldn't be any deeper than flush, it's not needed. If you insert it too deep there is a possibility that on the older plugs that the magnet will contact the clutch basket.
Old Dec 26, 2007 | 06:01 PM
rbabos's Avatar
rbabos
The problem with pipe thread plugs is that with each tightening, especially if you over do it, it will go in deeper each time. Follow the snug with 1/4" ratchet and it will be fine. Some form of thread sealant is a good idea.
Ron
Old Dec 26, 2007 | 06:35 PM
labfreak's Avatar
labfreak
12 to 14 foot pounds, if you got a torque wrench.
JohnFlorida
EVO
11
Jun 1, 2012 01:17 PM
rpmp3
Jan 20, 2008 10:12 PM
crzrlou
Jan 13, 2008 04:01 PM
blainem
19
May 30, 2007 04:29 PM
bancquo
25
Jan 24, 2006 02:11 PM
