FAT BOB rear axle nut covers
Old Dec 28, 2007 | 11:56 AM
storm8732's Avatar
storm8732
Default FAT BOB rear axle nut covers
Has anybody found a solution to the part listed in the catalog not fitting? There are three options listed, Smooth, Harley Logo, and Skull. the Skulls will fit but the other two options won't as the 08 Fat Bob at least has a larger nut than the 07 and prior. I am wanting to put on smooth covers front and rear. Just curious if anybody has come across anything that works.
Old Dec 28, 2007 | 03:53 PM
packetjunkie's Avatar
packetjunkie
Default RE: FAT BOB rear axle nut covers
Not much help here; I used the skulls which you already know fit.
Old Dec 28, 2007 | 04:08 PM
storm8732's Avatar
storm8732
Hopefully moco will figure it out soon.
Old Dec 28, 2007 | 04:10 PM
djwhaley's Avatar
djwhaley
I got the rear covers for Christmas and they dont fit my 08 fxdc Ive got a friend who is a Machinest maybe he can work this out
Old Dec 28, 2007 | 04:24 PM
stagolee's Avatar
stagolee
I'm in the same boat.
I'm wondering if the Kuryakyn covers fit our bikes.
Design-wise I prefer Kuryakyn products anyway. however it's painful to order an item from the web only to find that it doesn't fit in real life.
Old Dec 28, 2007 | 04:41 PM
storm8732's Avatar
storm8732
I would be a bit gunshy myself. The nut size increased for 08. I guess I will have to wait to see if I can find something locally
Old Dec 28, 2007 | 05:31 PM
SilentWarrior's Avatar
SilentWarrior
I had a big problem with the left rear axle cover. I ended up modding it to fit. I used the gapper from the front nut cover kit and cut it down to fit like a washer between the lock washer and nut in the rear. I then had use some J&B weld to get things snug. I redrilled a hole in the bottom of the cap to line up with the Nut. Then I drilled and tapped a hole in the top to line up with my newly made washer. Thats right, it was a real pain in the *** and took me hours to get it to stay tight. This was the only solution I could come up with. The right nut fit just fine. When I triedthe left nutwithout modding it it was easly pulled off and wouldnt stay due to the downward lip on the nut. Thank god for J&B Weld and a Dremel.
I guess paketjunkie got lucky.
Old Dec 28, 2007 | 10:54 PM
Fang's Avatar
Fang
I had the same problem...I put soft tail covers on mine...they have a slot in them ,but I just put the slot pointing down and they look fine.
Old Dec 28, 2007 | 11:19 PM
2007fxdc's Avatar
2007fxdc
Will these fit? I love mine. Gives some width from the back view too.
[IMG]local://upfiles/41150/F9C654CC9B7A451FA0462D0E284E904A.jpg[/IMG]
Old Dec 29, 2007 | 08:07 AM
TARTAN2's Avatar
TARTAN2
Working on some home made ones at the moment .
Will post some pics when I get done.
Its a real pain the lack of accessories but has got me trying alternatives........
