06 dyna drag bar question
Old Jan 8, 2008 | 06:11 PM
06 harley's Avatar
06 harley
Default 06 dyna drag bar question
i want to put drag bars with a 4 in. riser on the bike. the speedo is mounted on the bars. can you re-locate the speedo or should i leave it on the bars? i am new with harleys, so please be nice! thanks!---BRIAN
Old Jan 8, 2008 | 06:23 PM
crabs's Avatar
crabs
Default RE: 06 dyna drag bar question
Just tried mine with 4" risers and drag bars. looks good but no room for cables.And turn signals need to be moved.Think i'll try 8"next.
Old Jan 8, 2008 | 07:24 PM
chaelotte's Avatar
chaelotte
couple month ago i talk whit the stealler and he told me i need a 6' but if you want just chek the harley wb site and look in softtail motorpart you will see a kit that have everything you need to swap for a drag bar but it was made for a softtail not sure if it fit on the dyna but this kit come whit i think a 6" riser
Smiley51's Avatar
Smiley51
06 harley Do a search on drag bars on a superglide or moving speedo. There are several options some expensive and some not so much. I have drag bars with 8 inch rise and everything clears.
Smiley
PS the search option is at the top of the page. I'm not trying to be a smart azz I just see your newer from your post # and didin't knoe if you knew how. Good luck
Old Jan 8, 2008 | 07:39 PM
06 harley's Avatar
06 harley
thanks! i found alot of good info!---BRIAN
Gwjvw
Sep 30, 2014 09:14 PM
CGD
Nov 13, 2012 02:25 PM
jckazz333
Jul 12, 2011 01:24 PM
NewfieDyna
Aug 3, 2008 05:29 PM
Dethlace
Sep 11, 2007 05:15 PM
