smooth rear fender
Old Jan 14, 2008 | 10:30 PM
dklozik's Avatar
dklozik
Default RE: smooth rear fender
My turn signal wires are run inbetween my strut covers and fender struts. The electric board/plug that was in the taillight housing, is now under my seat.
Old Jan 14, 2008 | 11:35 PM
Nate's Avatar
Nate
I bought a wcc fender blank off of ebay for 125 shipped, used someelbowgreaseand rattle can paint. total cost= under $175
[IMG]local://upfiles/12377/C735BB8E63E343B6B5D158C052E8B09C.jpg[/IMG]
[IMG]local://upfiles/12377/D501498CEE6E462C9A298935C3C319D0.jpg[/IMG]
Old Jan 15, 2008 | 02:00 PM
buellrider76's Avatar
buellrider76
Which fender is that?
Old Jan 15, 2008 | 06:32 PM
JRK5892's Avatar
JRK5892
i also would like to know what fender that is... man Nate that is very clean and very sharp! I realy like how it swings just a bit lower than stock in back... very nive work!
Old Jan 15, 2008 | 11:39 PM
Nate's Avatar
Nate
it was advertised as a west coast choppers fender, however the box had a custom chrome label on it. Either way i don't care what it is. I believe it was an 8" wide fender. when I mocked it up to drill the holes I just mounted the fender lower to keep my ground clearance. I also had to take an angle grinder to the strut arms and knock off a little to get it to sit right. I don't know for sure but the whole fender might be on backwards but it looks good. I ran the turn signal light wires between the struts and covers and used the HD module to make them act as run/turn/stop lights and added LED bulbs. N8
Old Jan 15, 2008 | 11:43 PM
Nate's Avatar
Nate
I also did the SE 180 tire at the same time, you don't need the kit. Just make sure your wiring clears the tire/fender. If you run the wires along the fender struts you'll be just fine. N8
MrElectric03
Powdercoat & Paint
Oct 19, 2012 04:44 PM
128auto
Mar 26, 2012 03:17 PM
UT-rckr
Oct 5, 2011 08:20 PM
walkerinin
Mar 26, 2010 05:54 PM
DeuceRyder
Feb 18, 2008 06:55 AM
