TC88 Knocking
Old Jan 12, 2008 | 05:36 AM
2000fxdwg's Avatar
2000fxdwg
Default TC88 Knocking
I can't figure out where a strange knocking is coming from. The bike runs great but you can hear a clunk every so often. Changed the front isolator, adjusted the primary chain, and serviced everything...clunk is still there...only 8k miles. I'm hoping is coming from the oil pump or one of the cam chains.
Any ideas befor I have to shell out some dough?
Old Jan 12, 2008 | 05:48 AM
Critter174's Avatar
Critter174
Default RE: TC88 Knocking
depend on the rattle tc88 have what i call a chirp that comes from the rockers and is normal for HD seems worse after i put in SYN3 it its something else or if you are worried about it try to find a good Indy to have a look and let them hear it and see what they say the dealer will more than likely tell you there is nothing wrong with it while it's under warranty but when it's not under warranty they find all kind of things that need fixing. but i found a trust worthy Indy and let them do all the work i can't. and they are a hell of lot cheaper.
Old Jan 12, 2008 | 06:48 AM
Roadrocket's Avatar
Roadrocket
You didn't say what year but from your screen name is it a 2000? If so it might be the cam bearings starting to go. As critter said I'd get it checked asap. Whole lot cheaper to fix whatever it is now than after the fact.
RR
Old Jan 12, 2008 | 07:39 AM
bikerdog134's Avatar
bikerdog134
could also be something loose . its hard to tell sometimes where the sound is coming from. check for something loose before you shell out bucks
kipd
2014-2024 Touring Models
Sep 8, 2014 07:12 PM
milkbone96
Sep 6, 2010 03:06 PM
ArizonaFalconer
Nov 23, 2009 12:38 PM
neonhomer
Oct 26, 2008 05:59 AM
gsparesa
Mar 24, 2007 07:28 PM
