want a springer front end
Old Jan 12, 2008 | 11:17 AM
amish's Avatar
amish
Default want a springer front end
i have a 07 streetbob and want to put a springer front end on. what one do i need to get. like rake and length and all that.
please hepl me out im looking into it and would like to order somethign like this in the near furture
thanks for any help
Old Jan 12, 2008 | 11:53 AM
Sarge4life's Avatar
Sarge4life
Default RE: want a springer front end
I am in the process of doing the same thing. It seemed easy in the beginning, but the more research you do the more hickups you find. Stock length will work but a lot of people go one or two under especially if you have lowered the rear. You will also need to get a new wheel as springers use a 3/4" axle and the Dyna uses a 1", new risers and bars as springers have a wider spread between the risers, and a new caliper and pads. I feel like I am forgetting something. If I am, I'm sure someone else will add it.
Old Jan 12, 2008 | 12:02 PM
jackyl's Avatar
jackyl
p.m. (kpreese) he has changed his streetb0b into a springer.looks fantastic. jackyl
Old Jan 12, 2008 | 01:44 PM
cjhumphrey's Avatar
cjhumphrey
I've done it. It's not a simple bolt-on, but it's not super difficult either. You don't have to buy a new wheel. You can use your stock wheel and replace the bearings with earlier 3/4" ones. The front rim on my bike is the stock one.
Lee.moore1
Nov 9, 2016 04:08 PM
coma
Dec 8, 2015 11:58 AM
TedMan
Sep 27, 2010 11:43 PM
Daehawc
May 23, 2009 12:18 PM
AdrianVall
Oct 13, 2008 08:29 PM
