Throttle cable adjustment
Old Jan 13, 2008 | 01:25 PM
seaox's Avatar
seaox
Default Throttle cable adjustment
Hi I'm looking for a little help on the idle cable adjustment.
Just installed one of my Christmas goodies, skull hand grips and I ran into a problem with an adjustment after the grips are on the handlebars.
The service manual says to adjust the idle cable until the cable housing just touches the spring in the cable support sleeve on the carb. Sounds simple but for the life of me I can not see the spring. I've used mirrors, had a buddy look but the space next to the carb is so tight, just can't get to see inside the sleeve. If I tighten too much, the throttle sticks wide open, leave it loose it feels real sloppy.
Anyone have a suggestion or remedy? Thanks in advance. 2003 wide glide.
Old Jan 13, 2008 | 02:04 PM
jmpancoast's Avatar
jmpancoast
Default RE: Throttle cable adjustment
I would think you could adjust it by feel. Just adust it till you feel a 1/8 inch or lessof slack.
Old Jan 13, 2008 | 04:40 PM
cornishman's Avatar
cornishman
I had the same issues, so i set mine as jm said with approx 1/8" free play in the cable and its fine.
Old Jan 13, 2008 | 07:09 PM
TheeBoy's Avatar
TheeBoy
Agreed I just changes handles this afternoon, I adjusted the cables just by playing with them and feeling it out, turn left mke sure they snap back, turn right make sure they snap back and done.
see22ds
Apr 8, 2013 01:56 PM
2008 NIGHT TRAIN
May 9, 2008 08:13 PM
melnikmd
Exhaust System Topics
Feb 9, 2008 10:49 AM
kylant
Feb 6, 2008 10:15 AM
Whiffleboy
General Topics/Tech Tips
May 8, 2006 06:16 PM
