tacho's
Old Jan 17, 2008 | 08:48 PM
ggibson's Avatar
ggibson
Default RE: tacho's
Thanks for the options guys, all nice , all different prices ,the cheapest would be the Cobra at $240, then the alloyart/ tripletree nut one at about $350 , then the combo HD one at $500 but not sure if it fits a SB, tough decision, I think the Cobra one is quite different which is what I like but the alloyart one is what I was after in the first place. I have a nice HD embossed handlebar clamp which I likeand would have to lose if I went the Cobra way. Anyhoo waffling on now, thanks again for all your help guys.
[IMG]local://upfiles/47696/62586C1EC4B7464E92A584CCA896E5AB.jpg[/IMG]
Old Jan 17, 2008 | 09:34 PM
JRK5892's Avatar
JRK5892
Default RE: tacho's
I am putting a WG dash on my bob... here is the pre pic... not finished yet but it looks clean!
[IMG]local://upfiles/26534/6651C99DC13B4E1AA07A19C0DC153A56.jpg[/IMG]
Old Jan 17, 2008 | 10:26 PM
TheeBoy's Avatar
TheeBoy
Default RE: tacho's
Dude JRK, that looks sick, I need to see updates to your progress withthat. That's cool, I didn't think that was possible
Old Jan 17, 2008 | 10:34 PM
JRK5892's Avatar
JRK5892
Default RE: tacho's
it will be done by tomr night... i will post the pics! i had my original dash powder coated gloss black if any one is intrested in that
Old Jan 18, 2008 | 09:06 AM
Stanger's Avatar
Stanger
Default RE: tacho's
JRK,
This is the setup I was talking about earlier. It really does look good if you ask me and JRK you will like the setup. I am not sure how it will be on other years but on the 06 they say that if you take the time to look through all the wires in the tank area you will find the adapter for the tach. I am not sure, I just hard wired it to the existing wires and it works great!
JRK, if you need any help or questions, let me know.
Old Jan 18, 2008 | 03:44 PM
skip3406's Avatar
skip3406
Default RE: tacho's
ORIGINAL: ggibson
Would like to put a tacho on my Streetbob and was after advice if anyone has done it, what I would like to do is mount it on the lower side of the handlebar clamp as in part number 69439-06 but I cannot find a 'micro' tacho, maybe it would be to small anyway and I should get a 2 5/8" 'mini' tacho but cant gind a mount that sits on the low side of the handlebar clamp, anyone have any ideas??
I had to make my own bracket and I used the 2 5/8 mini tach.
Old Jan 18, 2008 | 04:05 PM
TOMMAY's Avatar
TOMMAY
Default RE: tacho's
Not exactly sure what you mean when you say you want to mount on the low side of the clamp. Mine is mounted on the rear riser clampbolts with the tach body facing forward,standard Harley part,think it was for an FL, but it works with some chrome washers to space it up a bit. Had to bend it a bit to clear my windshield but it works fine.
If you're really gonna used the tach for shifting when you're running all out I'd go with the 2 5/8 tach. The tiny ones are too hard to see.
Can't post pics here at work but there's some pics in my gallery.
Good Luck
Tom
Old Jan 19, 2008 | 07:58 AM
richdeerht's Avatar
richdeerht
Default RE: tacho's
I'd like to put a tach on my 2007 Super Glide Custom. The Cobra looks interesting, as does the Harley combo speedo/tach. Any FXDCI's here with a tach?
Old Jan 19, 2008 | 03:03 PM
ggibson's Avatar
ggibson
Default RE: tacho's
Nice job Skip3406, nice and tidy, you would have saved some bucks as all you would have needed was the tacho and tach sleeve, would that have been about $200 total?
[IMG]local://upfiles/47696/DDF470596958491396AF005A03926EA0.jpg[/IMG]
Old Jan 19, 2008 | 03:15 PM
EVO80's Avatar
EVO80
Default RE: tacho's
Harley used to make a bracket for, I think, the springer handlebar which i used to mount a Shift Gauge - see insert. If HD had a 1.5" tach with a shift indicator in it I probably would have put that in the mount rather than the shift gauge. One day I'll hook up my PC to my PCIII and use it to determine RPM's and mark the shift gauge so I have an idea what my RPM's are but for now I have a good idea if my engine is running steady just watching the shift gauge.
[IMG]local://upfiles/33976/9380DA34FBC74A148841D181D48D8990.jpg[/IMG]
