steering stem question
Old Jan 20, 2008 | 01:22 PM
ssls6's Avatar
ssls6
Default steering stem question
I just adjusted the steering bearings on my new 08 FXDWG. First off, I found the star adjust to be pretty loose so it needed adjustment. What suprised me was how sloppy the steering stem fit inside of the top triple clamp. The threaded shaft is 1" in diameter but the hole in the top triple clamp was around 1.25". Is there supposed to be a bushing that fits in that space?
While doing the work, I found a gas leak on the tank top plate. It looks like the screws were just loose...time will tell. The leak has warped my leather 105th strap between the tank and seat If it doesn't flatten out, then I'll have the dealer replace it. I hope I don't lose my numbered tag in the process.
Thanks,
RLK
Old Jan 20, 2008 | 04:08 PM
mud's Avatar
mud
Default RE: steering stem question
RLK, have a look here, and make your dealer aware of this issue.
bulletin m-1215A
https://www.hdforums.com/m_2709503/mpage_1/key_/tm.htm
mud
ORIGINAL: ssls6
Thanks,
RLK
Old Jan 20, 2008 | 04:28 PM
ssls6's Avatar
ssls6
Interesting. Thanks.
Old Jan 20, 2008 | 05:03 PM
ssls6's Avatar
ssls6
for what it's worth, my fuel leak repair didn't work. I took the top plate off and found paint chips under the rubber gasket. I cleaned the chips off, reinstalled everything, and now the leak appears to be fixed. Time will tell.
Passing Lane
Nov 3, 2018 11:59 AM
dwludwi
2014-2024 Touring Models
Mar 9, 2014 08:33 PM
blackbear
EVO
Nov 21, 2012 11:23 PM
nweb992000
May 3, 2012 12:43 PM
ironmnky
Jul 27, 2008 09:13 AM
