Fatbob Lights Help PLEEEEASE
Strange you mentioning the dodgy ground. 2 or 3 times now, the bike has lost all electrical power for a anywhere between a few seconds to a couple of minutes. HD Slough said they couldn't find a problem. Battery contacts are all fine.
This has now happened twice before the headlight change and once afterwards.
Any word on whether the light change affects the 2 year warranty? Just a scary afterthought.....Don't want to hear them turn round and say they wont investigate the power loss problm as I've monkeyed around with the headlamps!
I'd have another look at those battery connections, famously dodgy on many HDs. Take off the leads, give it all a good clean, apply a tiny coat of Vaseline and reassemble. Also take a look at the fuses; remove them, check for any corrosion, spray them and the area with WD40. Might also want to check all the connectors in that area and under the seat.
The warranty implications depend on the dealer. Some can be arsey and say that you touched it so its now your problem. Others will honor the warranty as long as its clear that anything you did didn't cause the problem. So, for instance, it would be a bad dealer that wouldn't fix a starter motor because you had changed the footpegs. I'd say you are getting close to the line with an electrical problem and you have made a fairly major change to the lighting, unless you already reported it to them before touching the lights.
That what a separate issue. The battery earth was ever so slightly loose. A quick tighten up by Harley mechanic and no problem since.
I'm now in this very strange place where absolutely nothing is currently wrong with my Harley.......
Feels weird.
Despite some of the electrical modifications I've done, I haven't had the pleasure of ANYTHING going wrong with my bike in any way, shape or form since I bought it in Jan '10... knock on wood... LOL
