Forward controls
Old Jan 27, 2008 | 12:27 PM
OhioSkully's Avatar
OhioSkully
Default Forward controls
Ok I need to see a cpl pics of forward controls on a dyna with the linkage like to see some kurykan and Harley Davidson so i can see any difference between the two before i order parts here soon.
Can either be installed with out removing the primary i have been told only the Kurykan can be done that way. but does the Kury have a offset linkage so if i ever want a custom linkage iam screwed as most are straight line.
Old Jan 27, 2008 | 12:44 PM
jmpancoast's Avatar
jmpancoast
Default RE: Forward controls
Harley Forwards on my 06 Super Glide. Installed these following the great post written by WS6 Formula. His method has been used by many here and doesn't require removal of the primary covers. It was one of my first mods. I didn't know anything about the Harleys. Took me about an hour to do.The pic showsthe supplied chrome plugwhich covers the hole in the outer primary.
[IMG]local://upfiles/23085/E912AADC152E43328D2BB0D0582E5059.jpg[/IMG]
Old Jan 27, 2008 | 12:54 PM
murphdog's Avatar
murphdog
These are the Harley controls on my 07. The inner primary came off on mine, but the only reason for doing that is to remove the original shifter shaft and to install a longer transmission lever. If you don't mind the old shifter shaft sticking out through the primary cover, you don't need to take it off. You can also saw through the old shifter shaft from the back side and remove it that way.
What kind of offset linkage are you referring to?
[IMG]local://upfiles/2952/53274C5020D442059B43C397D6C6D127.jpg[/IMG]
[IMG]local://upfiles/2952/25E1B4DD68DA405F9CD17F58C778F97F.jpg[/IMG]
Old Jan 27, 2008 | 01:03 PM
Fang's Avatar
Fang
Greetings fellow Buckeye! I have Kury's, I put them on myself, and had no problems at all, and I have NO mechanical skills! Go Bucks! Fang.
Old Jan 27, 2008 | 05:10 PM
XKROME's Avatar
XKROME
forwards and pipes where bought before i rode away from the Stealer
Old Jan 27, 2008 | 07:20 PM
OhioSkully's Avatar
OhioSkully
Maybe i was mislead i thought the Kurys had shifter linkage that was not straight sorry.
Now why is Murphdogs linkage straight and jmpancoast linkage angled down toward the derby cover what was different in the two harley installations?
and someone have a link to that article
Old Jan 27, 2008 | 11:51 PM
Jaybob07's Avatar
Jaybob07
Murphdogs had his primary off and installed the longer shift arm where jmpancoast just left the original one on there. I changed mine out as well myself. I did that when I put the back foot pegs on for my wife. I think I spent about 3 hours doing that, 2 hours was spent on the road and at Sears buying new tools that I did not have.
Old Jan 28, 2008 | 03:37 AM
expy's Avatar
expy
Kuryakyns. I did not remove primary.
[IMG]local://upfiles/34119/C8EB9218C302408E83E9F9908241F103.jpg[/IMG]
Old Jan 28, 2008 | 10:24 AM
rounder's Avatar
rounder
ORIGINAL: OhioSkully
Actually I have seen the crooked linkage as well on another bike ... I believe it was one with the 2 inch extention.
I have the H-D controls same as above... did not remove primary.... mine is an 05 though.
Old Jan 28, 2008 | 11:19 PM
OhioSkully's Avatar
OhioSkully
Good info thanks for all the help
