Anyone own a maintenance tachometer? They usually have an inductive type clamp for a plug wire. Hard time finding one that does 2 cylinders. I see some that do 4, but not sure if it would be accurate if halving or doubling the reading for two. Don't TC88's fire every up-stroke of the piston - thinking this would throw the tach off. Don't want or need a tach on my Wide Glide and she's carb'd, so need to set the idle other than "by ear". Thanks in advance.
Thats what I'm looking to get. Already have a multi-meter.
Cheers... Ben.
Ben - checked out the Tiny Tach site - looks like what I need. Too bad they only last 5 years though, but they are cheap enough! I am a bit confused about which one to get. Don't TC88's fire every up stroke? So would that be the 1C model or the 2C model of the Tiny Tach? I am thinking 2C, since a complete revolution (360 degrees) includes only one up stroke.
Hopeing someone else will chime in here to confirm this, but I'm pretty sure all Harleys are regular 4 strokes. Each cylinder fires once for every two revolutions of the crankshaft.
yup 4 stroke engine.... batteries last 5 years... maybe replacable...
I would say get the standard one(1st one listed or second if you want to reset the clock)
I kinda need one of these as well.....let me know if you get one and how it works out.....
Hmmm - I could have sworn I saw somewhere that Twin Cams have a different firing system than Evos and Shovels - it fires twice as often, every upstroke (once every 360 degrees of crank rotation). To me, that makes a difference in the tach I buy and I guess that's what's throwing me off.
[EDIT] - OK, I guess TC88's are the only big twins that have a single fire ignition, all older motors had dual fire. OK, so now I get why I was confused - it's a four stroke...thanks for the help guys, appreciate it.
SargeK
I believe the newer TC's are single fire ignition. Firing only the cylinder needed. The evo's and earlier were dual fire ignition, sending spark to each cylinder each time.
2C is the correct model. I have one about 1-1/2 yrs old. If you wanna try one, I'll sell this one. Don't need it anymore. Can take a pik if interested..
