what is the difference?
Old Jan 27, 2008 | 09:05 PM
impala's Avatar
impala
Default what is the difference?
Do all 96 motor bikes produce the same power?
I see on the t-max that there are different speedo calibrations for different bikes.
and different bikes have different back tires rolling circumference.
(not worrying about export)
I think all the 96 motors, primaries and 6 speeds are the same.
so is the power different on different models?
and if so, what order?
Old Jan 27, 2008 | 11:43 PM
dynasty's Avatar
dynasty
Default RE: what is the difference?
speedo calibrations have nothing to do wth horsepower. speedo calcs are dependent on tire circumference and gear ratios.
i believe all stock 96's to be the same. only difference would be weight to horsepower ratio.
Old Jan 28, 2008 | 09:56 AM
impala's Avatar
impala
ORIGINAL: jim carswell
So now I know my wide glide is faster than any stock bagger, simply because of weight.
and I was wrong in my thinking that a smaller circumference rear tire would be causing a different gear ratio and changing the power at the rear wheel.
Old Jan 28, 2008 | 10:01 AM
rounder's Avatar
rounder
actually the smaller circumference tire will have a faster spin up and spins at a different rate than a larger one at speed.
This is the reason for a different speedo calibration from one to the other.
Old Jan 28, 2008 | 10:35 AM
impala's Avatar
impala
ORIGINAL: rounder
now this I agree with.
a smaller rear tire will be like a smaller gear and give more rear wheel power and torque. given same engine, primary, and trans.
so a smaller rear tire might not look better it is faster. JMHO
Old Jan 28, 2008 | 10:45 AM
hmmr's Avatar
hmmr
i always understood it to mean it transfers the same power at a quicker rate, not sure how it can increase power. ..
but it's physics and about all i can do is spell *physics*
ORIGINAL: impala
ORIGINAL: rounder
Old Jan 28, 2008 | 12:11 PM
07bobber's Avatar
07bobber
IVE WONDERED THIS ALSO BECAUSE I HAVE A FRIEND WITH A BAGGER AND SOMETIMES I FEEL LIKE HE HAS A LITTLE MORE POWER ON TAKE OFF.........?
Old Jan 28, 2008 | 01:06 PM
rounder's Avatar
rounder
ORIGINAL: hmmr
ORIGINAL: impala
ORIGINAL: rounder
yup... just transfers at a quicker rate
UrbanRunner
May 13, 2021 04:44 PM
jeffjackman
The Dark Side
Apr 5, 2017 07:08 AM
dub976
Aug 6, 2012 12:24 PM
vinnieee
May 26, 2009 09:13 AM
DECON BLUE
Jan 3, 2009 09:16 AM
