Wide Glide Front End on 06 FXDBi
Old Feb 5, 2008 | 03:00 PM
doulos's Avatar
doulos
Default RE: Wide Glide Front End on 06 FXDBi
WS6 Formula is the guy to talk to. He really helped me a lot. I had never done a project like this and was a little intimidated butit wasn't that difficult. Disassemble as little as you can get away with.
Here's what I had to buy:
90/90-21 Avon Venom tyre,
21" inner tube,
21" wheel from a Wide Glide,
46700-06 Upper Triple Clamp,
46386-06 Lower Triple Clamp,
40923-06 Front Axle,
40926-06 RH/FRT Spacer,
40927-06 LH/FRT Spacer,
3/4" spacers and 3/4" longer Allen head bolts for mounting the fender,
washers (.090") to center the caliper over the rotor,
Here's the existing hardwareI was able to use:
brake rotor,
brake caliper and bolts,
axle nut,
triple clamp pinch bolts,
head bearings and nuts,
fender and nuts,
forks (49mm),
If you buy this stuff from the dealer it is pretty expensive. I pieced together parts that I found on ebay with parts I had to get from the dealer. I was able to find the triple clamps and wheel on ebay and saved quite a bit. Fender spacers were the most difficult things to find so I had to just get what I could and modify them.
Be aware that some of the existing hardware is metric i.e. caliper bolts, axle clamp bolts.
Old Feb 5, 2008 | 03:06 PM
doulos's Avatar
doulos
ORIGINAL: Priest
Looks really good, bro ... did you lower it, too?
Priest
Ilowered it with11" progressive 412s
Old Feb 5, 2008 | 03:10 PM
doulos's Avatar
doulos
ORIGINAL: ode sku
is your trees raked 3-degrees
I'm not sure if it's 2* or 3* but it's definitely more than stock
Old Feb 5, 2008 | 04:07 PM
KooeL49's Avatar
KooeL49
Awsome lookin' bike, did you give it a tank lift also? Later...
Old Feb 5, 2008 | 04:12 PM
Varmint's Avatar
Varmint
Hey Brother, u think you can post some pics w/out the back light? That SB looks sick. But the lights killin the detail.
Damn good lookin scoot Bro!
Old Feb 5, 2008 | 05:14 PM
dav.elis's Avatar
dav.elis
I've not understood about the trees... is it of Wide Glide? Is it not small for a street bob?
Old Feb 5, 2008 | 10:25 PM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: pastahcole
ORIGINAL: ode sku
ode sku,
Triple clamps are 2*
pastahcole,
Congratulations, looks to me like you did a good job, bike looks good. Looks like it has a more radical rake with the lower rear. How do you like the handling? Does the bike feel lighter and more responsive?
I've been eye balling headlights from Springers, Wide Glides, Sportster customs andSoftail Customs, and just noticed yours has a similar shape of what I've beenlookingat, what bike is your headlight from?
Old Feb 5, 2008 | 10:53 PM
metal_mike's Avatar
metal_mike
ORIGINAL: dav.elis
stock street bobs[fxdbi] have "mid-glide" width triple trees...roughly 8-1/2" wide center to center and no rake...
the wideglide[fxdwg] however...has roughly 10" wide trees and 2 degrees rake...
Old Feb 5, 2008 | 11:02 PM
traveler's Avatar
traveler
looks good!
~Joe
Old Feb 6, 2008 | 01:09 AM
abcd9906's Avatar
abcd9906
WS6FORMULA - Your front end is the stock Mid-GLide or has it also been converted to a WG setup? Looks like thePastahCole's bike has more of anexagerated rake on the front. May be just the pictures, butthat looks nice. I think the combo of tank lift, progressives, and the 2* made a HUGE difference in appearance on his machine (I'm Jealous!). It all goes together really nice.
PASTAHCOLE - I've never pulled the front end apart, everything behind it I have though*Anyways* Any words of advice, maybe some tips to make things easier that you may have ran into? What is the procedure for taking the upper and lower Clamps off besides your obvious fork legs and stuff. Do I need any new gaskets or do I have to Press anything in or is it all just hand tools and common sense or what? Thanks in advance. hehe
