Installing Works Shocks?
Old Feb 7, 2008 | 01:03 PM
beaverretriever's Avatar
beaverretriever
Default Installing Works Shocks?
When I install the works shocks, will there be any adjustment needed to the belt drive? The shocks are 11.5".
Old Feb 7, 2008 | 02:33 PM
beaverretriever
Default RE: Installing Works Shocks?
Anyone?
Old Feb 8, 2008 | 10:55 AM
beaverretriever
I know many of you have installed the Progressive Shocks. Is there any adjustment to the belt that needs to be done when you lower the back? Any help would be much appreciated. Thanks.
Old Feb 8, 2008 | 10:58 AM
CrashX's Avatar
CrashX
I went from stock to 11.5" and didn't have to. You're not changing the distance between pulleys, just the angle.
Old Feb 8, 2008 | 11:04 AM
chandler's Avatar
chandler
After changing the shocks check the tension and adjust accordingly.
Old Feb 8, 2008 | 11:28 AM
eazyride's Avatar
eazyride
yep, i also recently just changed the stock rear shockies 13.5 to 13' the 412s progressive. I know i should check the belt tension but keep forgetting.
lowering shocks or back is just changing the angle, not the distance. But if you lower the back too low, like really really low may be more than 3' lower, i really think you should really check the belt drive, and probably do some adjustments if needed.
Zeus55
Apr 6, 2021 11:55 AM
aqua mark
Apr 27, 2017 02:39 PM
normannewguy
Jan 23, 2016 01:10 PM
bran48
Apr 13, 2014 10:44 AM
dog155
Nov 23, 2006 09:50 PM
