Help with understanding rim/tire sizes?
you don't have to go up to the 18" wheels, you can use the 17" also. (the max is an 18")
i know the fxdwg and fxdl rear fenders are different widths, but the swingarm and main frame is the same other than rake in the front and triple trees. i put a chrome deuce rear wheel (17") on my 02 fxdwg with a 180 tire with no modifications. that same wheel should go on your fxdl, but a 160 tire would be the widest that would fit inside your rear fender. you might look at the deuce rear wheels (17" versions) - you can pick them up on ebay fairly inexpensive, especially if they are not chromed. just a thought - an 18" is not the only other option to the 16" you have now.
lasher 66:
what tire did you go with?
