New Suspension question
Old Feb 22, 2008 | 05:59 PM
Gurkha 1's Avatar
Gurkha 1
Default New Suspension question
I've got 1 inch lower shocks to put on my Wide Glide to replace the originals.
Is there anything I need to know or is this just a bolt off-bolt on job?
Old Feb 22, 2008 | 07:58 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: New Suspension question
It's not too terribly difficult I've done it around a half dozen or so times.It does help to have an extra set of hands because the suspension compresses when you remove one shock and it's a little tough to get the bolts lined up to put the new one on by yourself.About half the time I've been able to do it by myself the other half I had to get my wife out there to put the bolts in while I lifted up on the fender rail.
Old Feb 22, 2008 | 08:37 PM
DGlide04's Avatar
DGlide04
1" should not be a problem. Like Ed said, it can be done by yourself, one side at a time. Take your time, make sure you have every tool and part you need ot think you'll need. It is really a straight swap, should not take more than 1/2 hr. if you're not in a rush. One bit of wisdom though, check and double check for any clearance issues with the fender, wiring harness, etc. before you jump on and go searching for that first large pothole. And make sure all of the bolts are snugged down to their recommended torque values, you don't want any of the nuts falling off when you find that first pothole.
Old Feb 22, 2008 | 08:50 PM
Shrug's Avatar
Shrug
I used a floor jack and a wooden dowel to hold up the rear fender when I removed my shocks. It made lining up the new shocks a snap. Took about 30 minutes. Like DGlide04 said, have the torx driver and other tools on hand and it's a snap.
Old Feb 23, 2008 | 02:04 AM
Gurkha 1's Avatar
Gurkha 1
thanks guys
G
Old Feb 24, 2008 | 04:22 AM
Gurkha 1's Avatar
Gurkha 1
All done, looks cool, no snagging on the rear wiring loom. 1/2" shorter springs but the seat height drop seems bigger to my little legs.
Old Feb 24, 2008 | 09:26 PM
ehc0720's Avatar
ehc0720
ktm_scott; did you lower the rear ofyour WG? If so how much?
Old Feb 24, 2008 | 09:30 PM
ehc0720's Avatar
ehc0720
At the start of the thread your said 1" lower, at the end you said 1/2" lower?!?!? What springs did you change to?
Old Feb 25, 2008 | 04:40 PM
Gurkha 1's Avatar
Gurkha 1
They are 1" not 1/2.
Dunno where i got 1/2 from.
But it does feel more than 1" lower to me.
HD replacement springs.
The box says Premium Billet Lower Shocks.
They pre-load by screwing the top down, with 4 marker rings about 1/8 apart showing the amount of pre-load.
DiselDevilDog
Sep 11, 2012 08:39 AM
Smither's
May 16, 2012 05:45 PM
Micheletti
Dec 28, 2009 11:07 PM
will227457
Jul 12, 2008 03:38 PM
jp1212pc
May 30, 2008 07:22 PM
