Remapping required?
Old Feb 29, 2008 | 10:40 PM
maddoggreene's Avatar
maddoggreene
Default Remapping required?
Based on what I've read here I think if I just install slip-ons I don't need to remap. But If I install slip-ons and a new air cleaner (with higher flow) than the bike will run to lean and a remap is necessary. Do i have it right?[8D]
Old Feb 29, 2008 | 11:16 PM
carnes99's Avatar
carnes99
Default RE: Remapping required?
Yes. Just putting on slip-on's does not require remapping and even putting on an air filter doesn't require it. With the filter it is recommended but with the new EFI's you don't really notice the difference with the exception that the rev-limiter is raised.
Old Mar 1, 2008 | 01:37 AM
imboden's Avatar
imboden
ORIGINAL: maddoggreene
yes you have it right. if you mess with the air filter, according to the service manual and the service department, you HAVE to remap. more air flow= remap
if all you do is change the exhaust your good to go. check with your service department and you will hear the same thing, or read a service manual and you'll see the same thing.
good luck
Old Mar 1, 2008 | 07:27 AM
bikerx75's Avatar
bikerx75
Hello, new to the site! I put HD stage 1 high flow filter, with VH full staggered pipes, and with no re-maping. Only have about 100 miles on her, but no back fireing, and plugs look fine. (2007 FDX) I'll keep you all posted!
Old Mar 1, 2008 | 09:44 AM
RAWHIDE07's Avatar
RAWHIDE07
Theres an article in AIM magazine (APRIL 08) and thats exactly what they did.Picked up 10 hp and 6 ft.lbs of torque.
Old Mar 1, 2008 | 09:51 AM
traveler's Avatar
traveler
Guys,
Your bike comes from the factory with a tune that holds the motor back! If you are going to spend the money to make the engine run right, a re-map is the BEST thing you can do! The re-map lets the bike run the way it's supposed to, not the way the EPA wants it to!
~Joe
Old Mar 1, 2008 | 11:27 AM
103M's Avatar
103M
Guys,
~Joe
What he said!
103Ci, stage 2 , Screamin' Eagle Heavy Breather and Tommy Gun Exhaust
Old Mar 1, 2008 | 01:23 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: traveler
Guys,
~Joe
What he said x2
Old Mar 1, 2008 | 08:40 PM
bikerx75's Avatar
bikerx75
rawhide07- I justread that article in AIM, thats what I'am talken about!
Old Mar 1, 2008 | 10:11 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: bikerx75
Let us know what a new set of pistons cost ya in the next several thousnd miles
DougJ
