cable change out
Old Mar 6, 2008 | 02:32 PM
hddave2's Avatar
hddave2
Default cable change out
im thinking about a handle bars swap and was wondering what im up against as far as the cables and brake line..i have a manual but reading and doing the workcan be some what different.. im looking to go with streetbob bars..thank any advice
Old Mar 6, 2008 | 02:46 PM
Lone Watie's Avatar
Lone Watie
Default RE: cable change out
Actual procedure for thecable swapout I found easier than the manual makes it out to be.
Old Mar 6, 2008 | 02:52 PM
Travlinman314's Avatar
Travlinman314
ORIGINAL: lonewatie
I hope so, because that and forward controls are my weekend project.
Found this link, might help some more than the manual.
https://www.hdforums.com/m_342455/tm.htm
Honestly, I find myself scared to do things for the first time, but when it's over and done, everybody survives.
Old Mar 6, 2008 | 03:53 PM
hddave2's Avatar
hddave2
great info ..thank you
Old Mar 6, 2008 | 06:59 PM
jmpancoast's Avatar
jmpancoast
This is a write-up done about a handlebar swap. Includes clutch cable change-out. Take a look:
https://www.hdforums.com/showprofile.asp?memid=15261
Old Mar 6, 2008 | 08:26 PM
hddave2's Avatar
hddave2
well i just bought the idle, brake and throttle cables, used off a streetbob ..still need to find a clutch cable ..i think with all the good advice here i'll be able to get it all together fine...
Old Mar 6, 2008 | 11:14 PM
1nuckenfut's Avatar
1nuckenfut
Did mine last weekend. Took about 4 hours. I don't have a manuel and things went pretty well. Just take your time so you don't get ahead of yourself. Bleeding the brake is worst part of it. I was dredding the clutch cable because it seemed like it would take the longest but it was a piece of cake compared to bleeding the brake line.
Old Mar 7, 2008 | 04:37 AM
jmpancoast's Avatar
jmpancoast
I went to a local auto parts chainstore and purchased a vacuum pump. This was prompted by an hour of trying to bleed the front brakes. The $25.00 I spent on the pump was well worth it after the frustration I put myself through. I have used it a couple time since. Less than five minute operation now.
JLuns
Oct 10, 2012 10:40 PM
mastery
Mar 20, 2011 07:24 PM
JCFLHRS07
Apr 19, 2009 08:54 PM
jamesdeanblvd
Nov 18, 2008 11:21 PM
renegade75
Feb 5, 2008 06:57 AM
