Front brake light switch problem
Old Mar 14, 2008 | 06:09 PM
stang2811's Avatar
stang2811
Default Front brake light switch problem
Has anyone had a problem with a front brake light switch wanting to stay on all the time. I can loosen the handlebar clamp and move the master cylinder and lever, the tailight go out but when I tighten the clamp the light come back on. Also sometimes I can push the lever all the way forward and the light will go out. Any help would be great. Oh I forgot the bike is a 06 Superglide.
Old Mar 14, 2008 | 06:17 PM
Mabes's Avatar
Mabes
Default RE: Front brake light switch problem
I have a '99 FXDX and I had a similar issue in that I had to push the brake lever forward to get the brake light to go out. I ended up getting the rebuild kit for the master cylinder and that fixed the problem. I think the spring in the brake accuator was weak after eight years. I had previously replaced my front brake switch when it failed to light up the rear brake light.
Naz_Man's Avatar
Naz_Man
Here we go again, lol
There's a clip thingy that goes between your lever and the switch on the master cylinder and you either broke it or lost it or it could be pushed to the side..... I would carefully take it apart and see if it's broke or missing, if it's just pushed over some your in luck... I found the easiest way to put it back together without problems is to depress the lever a little while putting it together!
Hope this helped!
Donnie
Old Mar 14, 2008 | 06:34 PM
stang2811's Avatar
stang2811
Can you buy justthe clip thingy at the dealer, I am sure I lost itwhen I removed levers for powercoating
Old Mar 14, 2008 | 07:04 PM
Naz_Man's Avatar
Naz_Man
Old Mar 14, 2008 | 07:11 PM
Naz_Man's Avatar
Naz_Man
It's in a little rubber boot.....
Not sure if you can just replace the plunger and booty or not.... But when I broke mine on my sportster I just cut a small piece off a dead credit card and glued it to the lever where it hits the switch.... works great and it's still working 3 years later
Donnie
Old Mar 14, 2008 | 07:15 PM
06 harley's Avatar
06 harley
my bike has been at the dealer 3 times for the same problem and it is still not fixed!---BRIAN
Old Mar 14, 2008 | 08:05 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: 06 harley
Keeping in mind what Donnie said, I would suggest giving the dealership your credit card............. make sure it's an expired one, though.
DougJ
Old Mar 14, 2008 | 09:18 PM
stang2811's Avatar
stang2811
06harley
What did the dealer do to try to fix the problem
Erik Lundberg
Oct 19, 2018 01:59 PM
crabio
Apr 10, 2018 01:20 PM
EJ48
General Topics/Tech Tips
Nov 15, 2016 11:34 AM
apblingAEW
Oct 27, 2015 02:48 PM
beanbag
May 19, 2008 01:58 AM
