Problems installing new exhaust, re: O2 sensors
Old Mar 16, 2008 | 07:29 AM
encorebilly's Avatar
encorebilly
Default RE: Problems installing new exhaust, re: O2 sensors
Just put straight shots on this week.Have 2007 low rider with 10000mi.Put full exhaust on carpet and used 7/8 box end,one quick tap and came right out.
Old Mar 16, 2008 | 09:14 AM
manofsteele2003's Avatar
manofsteele2003
Yep, had the same problem with mine. The front one came out with no issues but the rear was a different story. I had to work it back and forth in order to get it out, and when it finally came out it looked as it was cross threaded. Talked to Trotter about it and he said that's a common problem and that it is not cross threaded but basically fused together by the heat of the motor, hence almost always the rear one. Luckily he was kind enough to give a spare o2 sensor he had so I could finish my install.
Old Mar 16, 2008 | 09:45 AM
1nuckenfut's Avatar
1nuckenfut
Marvel Mystery Oil is another excellent choice for breaking free stuck bolts. Put it on and let it sit adding a little throughout the day. You sit on them and get another gorilla (you said it) to yank on it. Let us know how goes.
Old Mar 16, 2008 | 10:28 AM
dynasty's Avatar
dynasty
patience my brother.... soak them with a penetrating oil, then soak some more. if you soaked them overnight you're probably done by now. heat of course works but you need some lubrication on the threads.
be sure to use anti-sieze when you reinstall.
goo dlick.
Old Mar 16, 2008 | 12:04 PM
LtRex's Avatar
LtRex
Penetrating oil, 22 mil wrench that is about 10" long, and have your neighbor stand there calling you a big "pu$$y", they will come right out!
[sm=escape.gif]
Old Mar 16, 2008 | 03:29 PM
jlb0038's Avatar
jlb0038
I put each header pipe in a vice, then used a large cresent wrench. That worked for me......
Old Mar 16, 2008 | 04:54 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: LtRex
[sm=escape.gif]
This would have to be my favorite reply
But don't forget the anti-seize or you'll be doing it all over again next time.
Old Mar 16, 2008 | 04:56 PM
Brewtality's Avatar
Brewtality
ORIGINAL: LtRex
[sm=escape.gif]
thanks for all the help. i'll give a few ideas a shot.
but i think LtRex has the winning reply!
Old Mar 16, 2008 | 05:50 PM
LtRex's Avatar
LtRex
Ha! I was being serious!! LOL
There is nothing like a jerk standing there running his gums to make you take it to the higher level!
[sm=laughat.gif]
Old Mar 16, 2008 | 06:25 PM
Brewtality's Avatar
Brewtality
ORIGINAL: LtRex
[sm=laughat.gif]
I know it's true!
Nothing will force you into another few reps on the bench press better than your spotter asking you if your vagina hurts!
