front pulley offsets
has the front pulley and primary been offset on the new er dynas compared to the old evos.
Reason i ask is I am running a 3" bdl open primary mated to a 6 speed revtech trans. Now as far as I know I can,t get a longer input shaft for the rev tech box so cant space the primary out like I did on My last chop.an`04twin cam night train
So I have been wondering what is the distance from the center of the wheel to the outside edge of the belt. I need to fit more rubber in the back and am hoping if I can fit one of the new 08 narrow rear belts and centre the wheel in the frame I will get at leasta good half inchback. I dont need to worry about the tyre clearing anywhere else as I have a JMC swing arm in for now and plan tomakea new single sided rear swing arm later and the body work will be done to match its just the inside edge of the rear belt that is Myt limiting factor.
