Please help - bike broke down
Old Mar 27, 2008 | 03:00 PM
atillman's Avatar
atillman
Default RE: Please help - bike broke down
check and clean the air filter too while you are at it...
Old Mar 27, 2008 | 03:13 PM
06SuperG's Avatar
06SuperG
Check the pitcock. My brother inlaw has a 96 Sporty that has a vacume hose on the back side.
Old Mar 27, 2008 | 03:32 PM
FatBoy94's Avatar
FatBoy94
I was thinking voltage regulator also. I had the same problem as this with mine and turned out to be the voltage regulator. I would not think the plugs would go out like that after it ran ok for a while.
Old Mar 27, 2008 | 07:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Loosen up the fuel cap and see if the bike will run a little longer, check the vent hole in the gas cap to see if it is plugged. I'm also leaning towards the trash/water in the fuel bowl on the bottom of the carb. pull the bowl off and clean it out and check that vacuum hose from the carb back to the petcock. the fact that you got some fresh gas and it acted up after restarting, did you turn the petcock back on after restarting the bike? Habits have to be reinforced after not being in them for a while.
Old Mar 27, 2008 | 08:18 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: seniorsuperglideE8
I go with this advice, keep it simple.
DougJ
Old Mar 27, 2008 | 08:24 PM
JRK5892's Avatar
JRK5892
KISS meathod works the best! same issues happend to my brother and it was a votage regulator... but what you bike is doing sounds more like fuel...
Old Mar 27, 2008 | 08:31 PM
R Racing's Avatar
R Racing
06 Super G has a point, If your vacuum hose to your petcock has a leak in it( And I have seen that and also a hole in the diafram) The bike gets no gas at all.
Jim
Old Mar 27, 2008 | 08:34 PM
2002flstc's Avatar
2002flstc
Sound like what happened to me in Wyoming last year on my way home from Sturgis...
Vaccuum hose to the fuel petcock came off behind the carb...
After a minute or two it would restart but would not go more than the 300 yards... Then I quit twisting the throttle and I could get it to stay running as long as I was very easy on the throttle....
Old Mar 27, 2008 | 08:35 PM
ezriderpgh's Avatar
ezriderpgh
Sticky float in the carb. Gumout should do it.
Old Mar 27, 2008 | 11:47 PM
dynasty's Avatar
dynasty
because it fires after a wait i think it's an electronics issue - the ECM? could be voltage reg as well.
crashin541
May 19, 2017 09:33 PM
Buzzfin
Dec 25, 2013 02:08 AM
PRobertshaw
Aug 7, 2010 04:05 PM
GypsyRoseTattoo
Exhaust System Topics
Jun 26, 2009 09:36 AM
firefighter3666
Sep 21, 2008 08:02 PM
