Tire question
Old Mar 27, 2008 | 03:08 PM
YoCon's Avatar
YoCon
Default Tire question
Ive searched this topic many times on different forums and still cant come up with a definitive answer. So, ill ask. Is anyone running a metzler me 880 150 on a 96-98 dyna series in stock configuration. I have a 98 wideglide and my 11" 412s will be on soon and new tire is definitely needed. I know a 140 will work but would like the look of a little more meat in the fender with a 150. Thanks in advance.
Old Mar 27, 2008 | 03:14 PM
DaxE's Avatar
DaxE
Default RE: Tire question
Not and exact answer to your question, but Metzler tires run smaller for the same ssize tire than other brands...I had about a 3/8" diffrence between them and dunlops of the same size.
wkdavistx's Avatar
wkdavistx
I'm not sure, I have a 2000 WG and just made room for a 150 by removing the sideplates and going to a detachable system for the sissy bar. The pre-99 Dyna fenders are narrower. By the way, I'm running the ME880 also.
By the way... was the stock size a 130/90-16? If so, when you go to a 150 you need to go to a 150/80-16 so that the circumference is closer to stock. This will keep your speedo more correct and help keep the tire from rubbing inside the fender.
Old Mar 27, 2008 | 03:30 PM
YoCon's Avatar
YoCon
yes the stock tire size was 130/90-16. The tire i have on now is dunlop d401. it has about 1/4 inch clearance to the belt. Ive been reading that the mtzs run smaller than dunlops. If the metz 140 is as wide as the dunlop 130 then i would be happy.
heavyd1
Nov 15, 2012 04:25 PM
strongwood
Wheels/Tires
Jul 9, 2012 05:29 AM
strongwood
Jul 8, 2012 08:10 PM
robertj74
Oct 29, 2009 07:42 AM
stbobber
Apr 7, 2009 09:36 PM
