i have a fork bag i want to use as a tool kit, what basic tools should i carry with me?
Old Mar 29, 2008 | 11:03 AM
freebyrd's Avatar
freebyrd
Default i have a fork bag i want to use as a tool kit, what basic tools should i carry with me?
suggestions?
Old Mar 29, 2008 | 11:35 AM
JRK5892's Avatar
JRK5892
Default RE: i have a fork bag i want to use as a tool kit, what basic tools should i carry with me?
do it all (multi tool), zip ties, electrical tape, go around your bike and find the most common rachet toss that in there, (most of the bolts and nuts are star (hex heads) toss that in there), small rachet, screwdriver philips/flathead, and a knife... then wrap it all up in a zip lock bag.
Old Mar 29, 2008 | 12:39 PM
baxter's Avatar
baxter
theres a whole bunch of em in the softy section! LMAO.............................................. .......................
Old Mar 29, 2008 | 01:55 PM
barhpr's Avatar
barhpr
[sm=boosign.gif]. LOL i carry enough to keep my stepdads dyna on the road [sm=smarty.gif]
ORIGINAL: baxter
Old Mar 29, 2008 | 02:02 PM
barhpr's Avatar
barhpr
ok all joking aside I carry 1 of each screwdriver, plug socket, elect tape, a few zip ties, a small tire repair kit, a cresent wrench, a miltitool, and a rag to wipe my hands off..I thought you guys just had tool bags just to make us not feel so bad???
Old Mar 30, 2008 | 04:56 AM
84FXRP's Avatar
84FXRP
I carry those tools needed to do a 10K mile inspection. The HD multi bit screwdriver is useful
as it has most of the torx bits needed.
Do the 10K inspection on your bike and you will see which tools you need.
I also carry a closed end wrench whose ends fit the front and rear axle nuts (made it with my welder).
I carry a tire repair kit and a battery powered tire pump.
Zip ties, electrical tape, pencil, multi-tool (pliers/knife/etc) and a small length of electrical wire.
Some miscellaneous nuts and bolts (1/4" 20 tpi bolt for the seat, bolt with lock nut that could
be used as the pivot for the brake or clutch levers - in case you lost a "c" clip), etc.
FWIW: my tire pump is about the size of your fist and costs about $10. Get one of the inexpensive
battery powered tire pumps from WalMart and strip off the outer plastic protective housing.
The pump works fine without the case, but you have to watch your fingers so you don't get hurt.
Plug it into the tail for your battery trickle charger.
Old Mar 30, 2008 | 06:10 AM
grumpa's Avatar
grumpa
84 and Joe ,
your guys are a world of knowledge,
aslice of rasin pie to yea all
Good Ideas.
outlaw0013
Aug 27, 2022 09:57 AM
justplainjohn
Jun 5, 2014 05:21 PM
freshman
Jun 21, 2010 06:23 PM
HDJIM1158
Dec 19, 2009 09:38 AM
cosmicHD
Sep 22, 2006 10:18 PM
