jump starting a bike
Old Mar 30, 2008 | 08:45 AM
gto frank's Avatar
gto frank
Default jump starting a bike
can you jump start a bike off of a car or truck was reading a post about you can hurt the alt. dont need to do this now but would like to know the correct way of doing this so i dont screw things up later also if a battery is dead and you jump start it how long do you need to ride it to charge it if it can even be charged after a jump thanks for any help
Old Mar 30, 2008 | 08:46 AM
Skaarsgard's Avatar
Skaarsgard
Default RE: jump starting a bike
I had a buddy who jump started his scoot using a car. He ended up ruining the battery. I don't know the actual technique to do it though.
Old Mar 30, 2008 | 08:49 AM
Bottomend's Avatar
Bottomend
Make the connection at the bike first. DO NOT have the vehicle running when you connect to it, DO NOT start the vehicle you are connecting to. I have never had a problem by doing it this way. Ride a tank of fuel through it and you should be fine, if that doesn't work hit the ol' battery store!
Old Mar 30, 2008 | 08:58 AM
PigInaBlanket's Avatar
PigInaBlanket
I jump started mine and had the car I connected to running. No problems.
Old Mar 30, 2008 | 09:54 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Why could you guys post this 3 weeks ago when I was on the side of the road? I waited untill 3 guys stopped.
Old Jun 13, 2015 | 05:57 AM
chefskeeter's Avatar
chefskeeter
I jumped mine three times and with the car running and have had no problems.
Old Jun 13, 2015 | 09:59 AM
Warp Factor's Avatar
Warp Factor
Maybe the battery was already bad, and that's why he needed a jump?
Old Jun 13, 2015 | 11:35 AM
skinman13's Avatar
skinman13
jumping a motorcycle off of a car battery is not a problem...I have done it many times. Although, I usually do not have the car running so the cranking voltage doesn't get too high during the start cycle.
Old Jun 13, 2015 | 07:25 PM
sharkey's Avatar
sharkey
Brothers bike had an "oversize" aftermarket starter and a POS aftermarket carb; would flood and kill the battery in less than 60 seconds of cranking. Boosted it a few times with battery from my truck, truck NOT running. Once boosted an oilfield engine and the draw on the RUNNING truck caused an alternator spike and wrecked $2G worth of modules; this after years of boosting from a running truck. I'll never boost anything again from MY running vehicle. (I realize that a HD would never draw that much) If it won't start right away, then fix what's wrong. In the case of bro's bike, put a stock starter and re-jetted stock carb on and it's a happy machine once again.
To sum up; I'd use smaller cables (my super gauge oilfield cables not necessary) and boost from the battery of my truck any day, with the truck NOT running...hooking to ground on bike frame and pos on bike battery; pos and neg terminals on truck. BTW; my local bike shop confirmed all the above.
Old Jun 14, 2015 | 12:55 AM
BigDogIdaho's Avatar
BigDogIdaho
I would personally do it from a non running vehicle just to play it safe. I can not confirm nor deny that doing so from a running vehicle damages anything.
Better yet but a booster pack and then you can jump start yourself !
