Need help diagnosing problem
Old Apr 3, 2008 | 10:42 PM
CSA's Avatar
CSA
Default RE: Need help diagnosing problem
Yeah that sounds like a bad Coil!
I have had that gas cap issue myself..........it was on a old Pick up truck though!
Old Apr 4, 2008 | 12:00 AM
Stretchman's Avatar
Stretchman
Check the key. If you have a lot of keys on your ring, it could be that the key switch is worn. Next time it happens, make certain the headlight is on.
If the bike stays running, like you indicate on your post, then it is probably the coil or the VR. A battery that is going can do that as well. There is a plug on the front of the motor by the oilfilter that comes off of the stator. Check to make certain that is in all the way. Check your grounds.
If the bike stays running, but doesn't respond to throttle, then it could be the cap. There are vent holes on the inside of it. Check to make cure they are clear. Remember, the throttle controls gas. Twisting the wick doesn't increase the spark timing, the engine itself does that. So if you are twisting it up and nothing happens but idle, then gas could be the cause. You are getting spark if the bike is running. Could also be the petcock. Have you checked it to see if it moves? Some people never touch theirs, and they get stuck, and clogged.
http://www.compufire.com/prices.html
Regular dual fire ignitions for about 100 bux.
VRs for about 85. If you know someone else with an EVO, maybe you can slave in the parts one at a time and see if it fixes it. Or check with your local wrench. Sometimes they have used dual fires for people who swapped out for single fire. If all you need it for is 20 mins or so to duplicate a probelm.
Old Apr 4, 2008 | 12:23 AM
JRK5892's Avatar
JRK5892
"I wouldn't waste my time fretting about it....it's an 07, take it to the dealer and make'm fix it."
look at that bro... your bike went from a 97 to an 07 i hope my bike gets younger in time! (just joking with you pappy)
did you check that spark?
Old Apr 4, 2008 | 07:06 AM
pappy43's Avatar
pappy43
OOOPs...my bad.
ORIGINAL: JRK5892
Old Apr 8, 2008 | 02:49 PM
shdwrdr's Avatar
shdwrdr
4th Gear
what do you guys think about the idea of the cam position sensor being the culprit? service manual shows this as a potential temp. problem.....
Old Apr 14, 2008 | 10:01 AM
shdwrdr's Avatar
shdwrdr
4th Gear
Once again, a large thank you to all who assisted getting me back in the wind. Turned out to be a bad coil after all and after replacing that with a new one and some new wires and plugs I am heading out again.......
Thanks brothers......
Old Apr 14, 2008 | 10:10 AM
dyna07custom's Avatar
dyna07custom
Good news glad you got it fixed
motochick55
33
Aug 10, 2019 03:54 PM
Crimson King
16
Feb 9, 2017 12:45 AM
1badbagger
Apr 9, 2011 02:19 PM
JDixon
Jun 5, 2009 02:10 PM
sschevelle
Apr 25, 2009 02:15 PM
