2" Lift Kit Help
Old Apr 3, 2008 | 09:47 AM
jasononaharley's Avatar
jasononaharley
Default 2" Lift Kit Help
I went to install the lift kit and while testing for clearance, I noticed the hose that runs from the console of my tank (not the wiring) has come loose. This is off of a 07 FXD. Is that hose supposed to connect to anything under the console? Do I need to take console off and reconnect it to something? Thanks!
Old Apr 3, 2008 | 09:49 AM
OSP1340's Avatar
OSP1340
Default RE: 2" Lift Kit Help
Yea, you need to take the console off to reconnect that.
When I did mine it did the same thing.
Old Apr 3, 2008 | 09:56 AM
jasononaharley
And to take off the console, do I have to undo all the screws around the gas cap as well?
Old Apr 3, 2008 | 10:46 AM
glide05's Avatar
glide05
ORIGINAL: jasononaharley
Yes
Old Apr 3, 2008 | 10:53 AM
jasononaharley
got it... thanks.
Old Apr 3, 2008 | 11:18 AM
SgtThump's Avatar
SgtThump
I'm asking this question, not trying to say I know the answer... But is that hose the tank vent hose? If so, where does the end that's not connect to the little tank nozzle under the console go?
Old Apr 3, 2008 | 11:40 AM
kk6pg's Avatar
kk6pg
Yup, its the vent.
The hose slips on to a one way valve that lets air in and vapors out, but closes when the fuel level is high in the tank so you dont have one of those unexpected surprises.
The other end is supposed to go to that little black canister that nobody seems to have anymore. If you never had the canister to begin with, then I suspect the hose just goes into the abyss, never to be heard from again.
Old Apr 3, 2008 | 01:36 PM
SgtThump's Avatar
SgtThump
ORIGINAL: kk6pg
Yup, its the vent.
Ahhhh, okay. I think Ido have that tiny little black cannister up in front of the tank.
cajun1957a
May 10, 2018 09:27 PM
PRrdglide
Aug 29, 2016 05:10 PM
Sarah93003
Feb 12, 2015 10:38 AM
jayhantz7
Apr 24, 2008 09:53 AM
2_up_FXDI
Aug 26, 2005 07:57 PM
