RevTech DFO ?
Old Feb 8, 2006 | 06:13 PM
theyogawarrior's Avatar
theyogawarrior
Default RevTech DFO ?
I've been leaning toward the SERT for my simple stage 1 mods but my mechanic is pitching the DFO as being just as effective for less money for these simple mods. When I do a 95 build next winter perhaps then get the SERT then he said. Thoughts? You can check RevTech site for more 411 if you need it. (It sells for about 200.00)
Old Feb 8, 2006 | 08:19 PM
SamStone's Avatar
SamStone
Default RE: RevTech DFO ?
I really like my DFO. I used the recommended settings for my mods and realized a world of difference in performance.
Old Feb 8, 2006 | 10:05 PM
CycleDrider's Avatar
CycleDrider
Ditto above with just the simple mods, use the DFO. Its simple to install and has good results. I have one as well. If and when I get to engine mod's I'll probably upgrade to a sert.
Old Feb 8, 2006 | 11:59 PM
phreak's Avatar
phreak
DFO here as well. Tried the PhuelPak phirst and it is a piec of ****!
It hasn't been redesigned phor the new electrical box on the 06's and therefore the ECM pigtail is too short.
The DFO however has plenty of wiring, and is an easy install. Baseline settings are good, maybe a bit rich at cruise.
Revtech unlike V&H has no problem explaining to their customers what each setting does.
Old Feb 9, 2006 | 12:07 AM
grizzly's Avatar
grizzly
Never heard anything bad about a DFO at all. I was not aware they had one for hte 06 Dynas yet...cool! mY buddy has a DFO in his E glide and loves it. He said it was an easy install as well.
Old Feb 9, 2006 | 12:11 AM
phreak's Avatar
phreak
1340ST is the new Revtech model # phor 06 dynas. Includes a connector phor the o2 sensors.
Try picking it up phrom Eastern Performace on ebay. They have a store, and the best prices around on them. Around 200
Old Feb 9, 2006 | 12:13 AM
HDF Tech's Avatar
HDF Tech
Unless you are going to do some more upgrades the DFI/TFI is a good choice and works well.
Here's some comparisons... https://www.hdforums.com/m_67296/tm.htm
$160 to buy here... https://www.hdforums.com/m_155046/tm.htm
More reading on FI controllers here... https://www.hdforums.com/forumid_247...smode_1/tt.htm
Old Feb 9, 2006 | 12:14 AM
grizzly's Avatar
grizzly
Great thanks. Now from what my freind told me, you just look up what add ons you have, and a chart tells you what settings to start with on the pots, and then if needed you fine tune form there right? I am good with the DL and the SEII slip ons for now, but if I decide to put the SE A/C back on I will have to go with a DFO or somthing.
Old Feb 9, 2006 | 12:16 AM
phreak's Avatar
phreak
ORIGINAL: grizzly
The package I got didn't have charts phor mods, but they have a phorum where the Experts phrom Revtech will answer those questions.
Old Feb 9, 2006 | 12:18 AM
HDF Tech's Avatar
HDF Tech
Here's the pot settings and the 800 number for tech support too.
https://www.hdforums.com/m_67610/tm.htm
