clutch assist?
Old Apr 7, 2008 | 11:29 AM
07bobber's Avatar
07bobber
Default RE: clutch assist?
how do i lube the cable? never done it before.......
Old Apr 7, 2008 | 11:39 AM
CSA's Avatar
CSA
Loosen the cluth adjustment so that you can remove the cable from the clutch lever. Once you have the cable out of the lever hold it straight up and use a good lube, like Tri Flow. You can get a bottle at the HD dealer for about 4 or 5 bucks. Any Car parts store will have something similiar. Pour 8 or 10 good drops down the cable and let is sit for few minutes let the oil run down the inside of the cable. Install the cable back to the lever and retighten your clutch adjustment. When you adjust the clutch, the clutch should be completely engaged just before the lever hits the stop. About the thickness of a dime of freeplay between the lever and the mount. Work the clutch get the oil traveling through the cable.
Old Apr 7, 2008 | 05:47 PM
WS6 Formula's Avatar
WS6 Formula
Here's some more information regarding the changes to the 2006 and up clutch set up.
Old Apr 7, 2008 | 06:29 PM
kk6pg's Avatar
kk6pg
This should be just what you need till your wrist gets better.
Just dont ask about an autoclutch.....
*hangs head in shame*
fabrik8r
Aug 30, 2022 08:45 PM
arnie54
Aug 31, 2017 11:51 AM
Jeff's 1st Harley
Nov 28, 2013 07:46 AM
Derv
Dec 13, 2009 05:54 PM
goutieboy
Mar 3, 2009 08:27 PM
