Just shocking
Old Apr 9, 2008 | 10:44 PM
Biker Bob's Avatar
Biker Bob
Default Just shocking
When I’m riding my 03 FXDWG I occasionally feel a shock when I touch my right thumb to the button housing. It doesn’t happen all the time, just occasionally. There is no rhyme or reason to it, just riding along and ZAPP!! There are no loose or damaged wires that I can find anywhere on the bike. No work has been done on the bars since it left the factory and the rest of the wiring is OEM as well. The regulator is in perfect condition as is the wiring harness that goes under the tank. There doesn't seem to be an obvious drain on the battery either. Has anyone else had this problem? Any ideas where to start to find the short? I have a multi-tester with an ohms meter & continuity that I can use to eventually isolate the short but was hoping the problem had been seen before. Thanks, BB
Old Apr 10, 2008 | 12:02 PM
tree88's Avatar
tree88
Default RE: Just shocking
check the condition of the small wire that runs from the right riser bolt to the chassis. I accidently left mine off when I first installed my apes, had the same thing happen. It is probably corrosion between it and the bolt causing higher resistance.
Old Apr 10, 2008 | 12:13 PM
07bobber's Avatar
07bobber
BUT MAKE SURE YOU TAKE THE GAS CAP OFF FIRST ..........THEN START THE BIKE AND THEN PRESS THE BUTTON..............J/K
Old Apr 10, 2008 | 12:18 PM
Biker Bob's Avatar
Biker Bob
In addition to the previous post when I am not touching the button housing with my thumb and my knee is touching the tank I get the shock on my knee. It is intermittent but very annoying. Thanks for any tips, Bob
Old Apr 10, 2008 | 12:24 PM
Donny's Avatar
Donny
Could be your clothes creating the static. Ride up to a metal fence, light pole, etc that would be grounded, and see if you get the same shock, if so, use some dryer sheets in your laundry. Sounds stupid, but it HAS happened to me before.
If not, then like tree said, check the small ground wire running from the riser to the frame. If that's ok, start checking other grounds.
Old Apr 10, 2008 | 01:03 PM
Biker Bob's Avatar
Biker Bob
Thanks for the tip Tree, I checked the continuity between the ends, all around them and on different grounded components and it's all grounded. No corrosion or grounding problems with that wire at all. I even checked between the wire and the button housing as well, all continuous. I pulled the seat and removed the battery and re-checked all the wires from front to rear with no signs of damage or shorts. With the gas cap on I might add07Bobber(lol). Does anyone know if the stator can short out? BB
Old Apr 10, 2008 | 01:09 PM
dyna07custom's Avatar
dyna07custom
I doubt the stator would give you a small shock plus you would be having battery problems you providing a ground for something in that housing a wire has to be pinched or broken somewhere or the switch is grounding out
Old Apr 10, 2008 | 01:11 PM
Biker Bob's Avatar
Biker Bob
ORIGINAL: Donny
Thanks for the tip but it is a pretty good zap, not like built up static at all. Not as bad as a coil bite but close enough. Usually I’m just wearing cotton and leather, I don’t think they make static but I’ll keep your suggestion in mind. I’m really suspect of the regulator orthe stator. Thanks, Bob
Old Apr 10, 2008 | 01:25 PM
Biker Bob's Avatar
Biker Bob
ORIGINAL: dyna07custom
If I don't find any other obvious wiring problems I will take your advice and crack open the housing and look for pinched or loose wires. Thanks, Bob
Old Apr 10, 2008 | 02:06 PM
Biker Bob's Avatar
Biker Bob
Is this right? I have the battery removed from the bike and when I check the continuity between the positive connection for the battery and the handlebars I get no continuity when the ignition switch if off or on Accessories. When I turn to Ignition (on) I get continuity. It’s just completing the circuit right? If there was a dead short it would show up with the switch turned to accessories or even when it’s turned off. Or am I missing something? Thanks for the tips, Bob
Boo2you
May 14, 2010 04:39 PM
HemiGlide69
Apr 2, 2010 08:02 AM
CrackOfDawn
Aug 6, 2009 03:47 PM
Biker Bob
Apr 11, 2008 11:54 AM
dav7963
May 21, 2007 10:48 PM
